Author Topic: Yet another Tempest - Done!  (Read 10122 times)
Barry Barcrest
  • Last login:November 09, 2021, 09:54:17 am
  • Simple Plan
    • E-Touch Jukebox
Re: Yet another Tempest - Done!
« Reply #40 on: December 06, 2007, 07:17:27 am »
Dude that's awsome, have you thought about running the PC Version of tempest on it? Seeing as you have XP installed already.
Paladin
  • Mmmm llamaburgers!
« Reply #41 on: December 06, 2007, 08:25:34 am »
That would be awsome, but I've got the monitor mounted vertically and I don't think the PC version will rotate.  Does anyone know if it's possible?
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #42 on: December 06, 2007, 09:16:10 am »
You can rotate the XP desktop so it shouldn't matter if the PC Software rotates. Most graphics card drivers support rotation. I just don't know how stretched it would look, still worth a try.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #43 on: December 15, 2007, 08:30:32 pm »
You could try running this one...
http://typhoon.kuto.de/download_mirrors.html
Windows and Linux.
rrcade
  • Last login:December 03, 2019, 10:37:08 pm
« Reply #44 on: May 10, 2008, 01:37:15 pm »
Paladin, I PMd you but don't know if it went through, anyhow here's what I sent:
Hello I could really use your input. I did exactly what you did with my tempest even ordered the same optic boards, after playing with my mini pac wiring I finally got the tempest spinner to work. I have a couple questions, first my spinner controls my mouse pointer in a left to right pattern, is this correct or should it move it up and down?  Second how do you select a game to play assuming you're using a frontend of some kind. Lastly what settings are you using in mame to reduce backspin?
My machine will be running a couple different Tempest games, tubes, and some Misfit Mame hacks, the frontend will be Maximus Arcadius and I would like to keep the controls stock and still be able to scroll through the few games and select them to play. Any advice on how you set up your machine would really be appreciated, I thought this was gonna be simple now I"m stuck.
Thanks a LOT
Jamie
Paladin
« Reply #45 on: May 11, 2008, 12:26:18 am »
Sorry, I just got your message today.  I replied to your message.  I sold the machine, but if I remember right I used speed 20 and sensitivity 25.  Older versions of MAME used to have that as a default, but newer ones seem to have sensitivity set at 100.
I had my cab boot right into Tempest with no front end.  Most front ends allow you to choose what keys move you through the menus, so I'd use p1 start and p2 start to move up and down through the menus.  I'd then set the fire button to start the selected game, and finally p1 and p2 start at the same time to exit a game.
I hope that helps!
Tom
