Author Topic: Newb Question. Router Template?  (Read 2411 times)
fjl
  • Pixels Rule!
« on: April 03, 2007, 02:11:53 am »
http://www.amazon.com/gp/product/customer-reviews/B000063XTX/ref=cm_cr_dp_pt/103-9327946-0211857?ie=UTF8&n=228013&s=hi
How exactly are these used and what are they supposed to do? I really don't know what their purpose is... Sorry, I guess I'm just a total newb.  :dunno
« Last Edit: April 03, 2007, 02:29:38 am by efjayel »
Rusty
  • Last login:March 06, 2010, 10:46:24 am
  • Ow! Ow! Ow!
Re: Newb Question. Router Template?
« Reply #1 on: April 03, 2007, 09:33:12 am »
Template guides or bushings are used to follow a template.
This page should explain it a little better than me.
moriartyds
  • Last login:November 05, 2007, 09:09:39 pm
« Reply #2 on: April 03, 2007, 10:00:19 am »
The link Rusty provided looks pretty complete.
The shorthand version:
 - The template guides you linked, attach to the router base (method depends on model) and surrounds the router bit.
- You create a template that is slightly bigger than the final shape (see the section on critical distance)
- Clamp your template on top of your final piece.
- Route letting your template guide follow your template.  The guide will ride along your template (while preventing the bit from routing out your template).  The part of the bit that is exposed below the bushing cuts the bottom piece out.
edit:  if you're confused about how to make a template, check out the top/bottom mount joystick jig thread stickied above for an example.
« Last Edit: April 03, 2007, 10:07:31 am by moriartyds »
fatfingers
  • Got UltraStiks?™
« Reply #3 on: April 03, 2007, 10:42:50 am »
So why would a person use one of these instead of a template cutting bit (I think that's what they're called?)
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
« Reply #4 on: April 03, 2007, 11:42:21 am »
Template or pattern bits are straight cutters that are only designed to route along the side of a workpiece.
Template guides (a.k.a. bushings) work with a larger number of bit types (e.g. dovetail, v-groove), which gives them more flexibility. There are kits, for example, that combine a v-groove bit with a guide bushing and allow you to route letters in the top of your work. Move dovetail jigs also use template bushings.
Rusty
  • Ow! Ow! Ow!
« Reply #5 on: April 03, 2007, 12:39:06 pm »
Yeah, what Scott said.
For many more common purposes, such as building a joystick recess jig either a template bit or bushing would work.  Bushing guide sets allow for more flexibility in depth of cut and template thickness.  You don't need to buy a special bit for each different jig you need.
