Author Topic: Can't remap controls when using LEDBlinky  (Read 1302 times)
orbian
  • Last login:September 13, 2007, 01:27:17 pm
« on: April 02, 2007, 06:10:50 pm »
I ma using the LEDBLinky plugin for MALA. The problem is that when I go into the game and remap controls they won't save when I exit the game. I have to remove the LEDBLinky plugin, start MALA, start the game, remap the controls, then get out of MALA and re-add the plugin in order for the correct mapping to save. Has anyone else seen this problem>
Thanks,
Bob
DJ Infinity
  • Last login:January 19, 2012, 03:48:16 pm
Re: Can't remap controls when using LEDBlinky
« Reply #1 on: April 11, 2007, 05:45:13 pm »
I'm about to give the ledblinky plugin a try here in the next few dayz. I'll let you know
If You Are Going To Meddle At Least Listen
arzoo
  • Last login:March 24, 2026, 08:14:12 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #2 on: April 12, 2007, 10:27:48 am »
Sorry guys, I've been very busy and off the forum for a while. Here's an updated version of the plugin which should fix that bug. Unzip all the files into the plugins folder and overwrite any existing files. You'll need to rerun the config app to set the options and folder paths, but the mapping and profile files do not need to be recreated. Let me know if this solves the problem.
LEDBlinky v1.0.1
Robots will kill you.
Arcade Addiction
