Author Topic: Hi Score problem on Shutdown  (Read 1251 times)
johnm160
  • Last login:April 09, 2024, 09:00:46 pm
« on: April 01, 2007, 02:25:01 am »
Well I discovered a problem tonght will working on my Tempest replica.
Since it is only one game I am not running a front end.
Here is my problem, if I just press the pc power button the system shuts down but does not save the hi score. If I exit the game and press the power button the Score is saved.
I am trying not to make the shutdown a two step process because I know the kids will not do it right.
Is there a way to run a batch file on mame exit to shut down the pc?  Or is there a fix for the hi score problem?
John
johnm160
Re: Hi Score problem on Shutdown
« Reply #1 on: April 01, 2007, 02:44:56 am »
nevermind, I think I have a work around.....my brain is fried at this hour.
Will call tempest from a batch file, will put a shutdown command in so when you exit mame the batch file will take back over and shut the system down.
Might put a choice in for the rare occasion that you don't want the system to shut down.
something like system is shutting down. press player 1 start to continue or player 2 start to abort.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #2 on: April 01, 2007, 07:31:18 am »
The other option is to put the system into, dormant mode with all the hardware shut down... When you then re-apply the power the whole thing should come back in exactly the same state it was in when it was shut down.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
johnm160
« Reply #3 on: April 01, 2007, 12:35:32 pm »
Fozzy,
I was using hibernate for a while, I would have problems with it crashing when it came back on. I think the new display drivers fixed that but now I get hung up at a password prompt when comming out of hibernate.
I manage the machine now with remote desktop and if I remove the password remote desktop does not work.
I have the machine set to auto login, is there a setting like this for coming out of hibernation?
