Author Topic: Help required with joystick when using: Arcade Stick & JoytoKey & Atomic  (Read 2447 times)
Dariusz
  • Last login:November 23, 2018, 02:41:36 pm
Hi,
I have sa etup where I have a Xbox arcade joystick (arcade stick) connected to the PC using a xbox to pc converter - super joy box 10. The converter uses the Tigergame xbox to USB Controller software, located in the game controllers option under the control panel under in vista.
The properties of the tigergame indicate the joystick is working. ie. If if you move the joystick left, the calibtation window indicated you have moved left and so on.
I  run joy10key (version 374en), and its been configured using the auto setting wizard ie. left arrow key has been assigned to the left joystick control and so on.
I run the FE Atomic, and my problem is the joysticks analog controls are activated (2 trackball control like devices), and I do not know how to swtich it off (the red light on the joystick is on where it has a label -  analog), as this caused the joystick not to work under Atomic (ie. moving te joystick up and down does not scroll throught the games list), but the track ball like devices up and down operation does scroll through the game list!
Would any one know how I can get the joystick part of the arcade stick working (disable the analog trackball trpe devices)
Dariusz
« Last Edit: March 31, 2007, 07:57:45 am by Dariusz »
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Hi,
I'm not sure i understand well your problem. But it seems you have some kind of conflicts between Joystick Mode and Keyboard mode?
If what you need is to make Atomic not sensitive to Joystick , you can put that line in your .CFG files :
IGNOREJOYSTICK=YES
Be sure to have got the LAST patch of Atomic 0.19  from my website.  This options is not available if you don't have the patch.
I hope it helps.
