Author Topic: MAME INTO CABARET CAB (PAIN IN THE ASS)  (Read 1487 times)
hayabusa_fmw
  • [Provisionally returned]
  • Last login:December 30, 2014, 03:24:56 pm
« on: March 30, 2007, 04:18:26 pm »
hey guys
Im trying to finish up my mame cab
it's pretty a pain in the ass since starting the project
first the monitor that was inside was ''a 13''
so im putting a 17'' pc monitor...
so i had to cut a hole into the door & recover it with an other peice of wood but the other side..... so it looks ''ugly but still you never look at a cab's behind....(don't we?)
haha
nayways
my question is the following
How can i put brackets for the monitor to hold...
& be straight
I tryed drillings some little L brackets it didn't do the job
now the monitor is holding by some Wood on top & on the bottom i couldn't put a long peice of wood so i put only 2 squares of wood so it can slide in & hold there....
everything is bolted with washers...
but it sucks...
i don't like my project so far... but i guess i could live with it if the monitor could be straight  straight dead center...
SithMaster
Re: MAME INTO CABARET CAB (PAIN IN THE ASS)
« Reply #1 on: March 30, 2007, 04:34:52 pm »
could you take a pic of the area?
Crowquill
  • Last login:March 30, 2026, 01:03:12 pm
« Reply #2 on: March 31, 2007, 04:04:40 am »
Pics would definitely help.
Do you want it stable enough to just sit in the cab correctly or do you want the monitor permanantly bolted in there?
hayabusa_fmw
« Reply #3 on: April 01, 2007, 10:38:36 am »
I want the monitor to never move again
i don't see the point of taking it out once the ''cab finished''
but now i drilled too much time on one of the side so the screw is loose on the bracket
so i tryed putting a bigger gauge of screw wich didn't worked really
so if i shake it a little it can move a tiny bit but ppicky as i am it bothers me so much to know that ..
:what i did ...''
i took Flat backets & put them on all 4 corners of the monitor & then i took a wrench & put them secured there  & put peices of wood to slide it in
but what i would like is do a cleaner job & so it's VERY hardly bolted into the cab & straight
pics :
im not happy of the job i did but not at all .
i would like to find a way to make it cleaner & very solid
The backdoor part i don't mind since no one will see it even if i didn't have a back door ...
thanks!!!
