Author Topic: Monitor Problem :(  (Read 2308 times)
CRiMiNaL
  • Last login:January 31, 2026, 01:28:11 am
Monitor Problem :(
« on: March 29, 2007, 12:55:20 pm »
hey,
I have a 9" Hantarex MTC 9000 Monitor, and I'm trying to hook it up to my computer with a trident blade vid card in dos with the bladetsr.exe 15khz video patch. This isn't my first arcade built, so I'm pretty sure I've hooked everything up right.
I have the arcade video hooked into the video card with a hacked bnc cable, 5 wires come out of the bnc, red-green-blue-ground-sync, so when i hook it up to the monitor the screen just changes a bit so i know it's getting a signal, but the screen just stays light grey.
grantspain
Re: Monitor Problem :(
« Reply #1 on: March 29, 2007, 01:47:29 pm »
double check the ground and sinc wires are in the correct place,also there is a large contrast pot-make sure that is not turned right down
CRiMiNaL
« Reply #2 on: March 29, 2007, 01:58:51 pm »
thanks, but I double checked and still no picture
grantspain
« Reply #3 on: March 29, 2007, 02:04:37 pm »
well its only gonna be the input signal or a blanking fault on the monitor,the latter being very unlikely
are you using component video from the vid card?
CRiMiNaL
« Reply #4 on: March 29, 2007, 02:21:16 pm »
i'm using the normal vga hook up
CRiMiNaL
« Reply #5 on: March 30, 2007, 08:12:53 am »
Ken, do you know what the problem could be?
CRiMiNaL
« Reply #6 on: April 02, 2007, 12:44:38 pm »
bump
SirPeale
  • Green Mountain Man
« Reply #7 on: April 15, 2007, 07:13:40 am »
You may need a video amp.
