Author Topic: Happs Vision Pro HELP NEEDED *****  (Read 2003 times)
koolmoecraig
    • My Intervention
« on: March 23, 2007, 05:59:10 pm »
Does anyone know how to adjust the horizontal position to the right further than the remote pcb lets you?
Anyone?  Is there a jumper or something?
draginit
  • Last login:December 26, 2023, 12:59:18 pm
Re: Happs Vision Pro HELP NEEDED *****
« Reply #1 on: March 24, 2007, 03:58:49 am »
i had this problem for awhile, but just the opposite, i couldnt get it to fit in the screen(too wide),, what i found was a simple adjuster on the bottom board and carefully adjusted that by turning it the direction nessacary,,  i had a mirror on the other side to see what was going on with the screen.
-assuming its the vision pro 27",...in your manual, go to page 8..its in the bottom pic labeled sub H size(VR402)... really simple to do.
koolmoecraig
    • My Intervention
« Reply #2 on: March 25, 2007, 02:19:50 am »
This is on a 19" CGA one.
I don't see that adjustment anywhere.
dam it
koolmoecraig
    • My Intervention
« Reply #3 on: March 26, 2007, 07:52:32 pm »
Hey all.
I figured it out for anyone having the same problem.
There is a tiny tiny button on the chassis.  Its white with a black center. You push it in to pop it up and the image will shift about two inches.
PERFECT.
