December 13, 2025, 06:14:28 am
0 Members and 9 Guests are viewing this topic.
I went to get .113u2 and it isn't there. Is there a problem with the link? Also, I am brand new at highscore.diff - I downloaded the latest version of high score.diff and placed that it in the mame directory. I placed it just as it is. i.e. - "mamescore.diff" I am using commandline mame (.113b) and mala as the front end. Is there anything else I need to do to get the highscores working? Is there anything else I need to set?
hi mkchamp i have uploaded the latest mame 0.113u2 with hiscore support added to :- www.mameworld.net/highscore along with the latest hiscore.dat with a few more games added i hope you don`t mind me uploading the mame which was made possible with your hiscore.diff file.
hi mkchamp i have uploaded the latest mame 0.113u2 with hiscore support added to :- www.mameworld.net/highscore along with the latest hiscore.dat with a few more games added i hope you don`t mind me uploading the mame which was made possible with your hiscore.diff file.many thanks,Leezer
I get a File Not Found when I try to download this. Bad link?
I am able to patch 113u1.diffI am able to patch 113u2.diffbut when I try to patch hi_113u2_noNag.diff
Quote from: Bender on June 25, 2007, 07:36:56 pmI am able to patch 113u1.diffI am able to patch 113u2.diffbut when I try to patch hi_113u2_noNag.diffIt's been a while since i've done this, but try not chaning the file type. I.e. you should be typing in this:patch -p0 -E <hi_113u2_noNag.txt (not a .diff).
there are a lot of different replies to this thread, all with different files attachedcould someone write the steps?Pick one version of MAME and please walk thru one step at a time...THANKS!
Ok, the sets i listed above have seemed to of worked . But i can no longer getting into any options in the 'TAB' menu now. How do i set it back so when i press the tab key it doesnt also pause a game?
Quote from: lettuce on July 28, 2007, 09:08:36 amOk, the sets i listed above have seemed to of worked . But i can no longer getting into any options in the 'TAB' menu now. How do i set it back so when i press the tab key it doesnt also pause a game?I don't use Mame32, but I think any changes to the key that brings up the options menu while playing a game is stored into the default.cfg file located in the cfg folder. Try renaming default.cfg to something else. When you run a game, a new one will be created hopefully restoring TAB as the key that brings up the option menu.
Ok now im not sure if im doing this right. Now i have the source of 0.117, so i should follow Mr Do instructions and get 0.117u1.diff, and edit the patchmame.bat to add this 0.117u1.diff and the use patchman. After ive done that step do i need to use makemame, or do i have to get the hi_117u1.txt and edit the patchmame.bat again so it uses hi_117u1.txt, then after thats done use makemame, or do i have to use patchmame then makemame for 0.117u1.diff then repeat again for hi_117.u1.txt???
