Author Topic: visual pinball and vpinmame can't get working help?  (Read 5795 times)
tyweed
  • Last login:March 09, 2008, 01:29:03 pm
« on: April 08, 2003, 02:16:00 pm »
I'm trying to get visual pinball and vpinmame to work but i'm having a very hard time. I installed visual pinball placed tables in table folder .then installed vpinmame and put roms in rom folder. when i test roms via the setup screen foir vpinmame everything works great. but now i'm trying to get that led screen to show up on the pinball game and it won't any ideas why? i tried posting at that vp forum and got no help this forum is much better lease any ideas would be great. oh also i placed a script vsbsp3.0 or something in visual pinball table section so i think i inswtalled everything ok?
BobA
  • What Me Worry?
Re:visual pinball and vpinmame can't get working help?
« Reply #1 on: April 08, 2003, 02:58:25 pm »
OK you said vpinmame installed and tested out OK.  To get a playable game use visual pinball to open a file from the tables sub directory.  When it opens select play and the table should load and say preparing table.  Vpinmame should then come up and you click on it to play the table.  You will probably get a do you own this table display the first time you play it.
Once you get that far you might want to try VPLauncher.
BobA
tyweed
« Reply #2 on: April 08, 2003, 08:00:58 pm »
right when i click on a game in the tablews sub folder it builds the game then i play.Never does it load in vpinmame? where do you think the problem may lie it seems its not reading vbpinmame? there is a file i downloaded at "IR Pinball" its called vbs script"(Version 3.10) Required for ROM emulation in solid state tables" i extracted this and put it in tables folder is this what reads vbpoinmame and tells it to load?  also last question fonts are kinda messed up so i saw there is a vp fonts where do i place this file? i have it extraced in tables folder and it did not help?
BobA
  • What Me Worry?
« Reply #3 on: April 08, 2003, 11:23:59 pm »
The vbs scripts are in my tables folder as are the font ttf files.  Did you unzip your vpt and assoc files into the tables folder?  I unzipped each table zip into the tables folder.
BobA
Chris
    • Chris's MAME Cabinet
« Reply #4 on: April 09, 2003, 03:57:17 pm »
If the table loads and plays without an error, then VPinMAME is loading; the display may just be off the screen or something.  Is there a particular table you are trying?
--Chris
--Chris
tyweed
« Reply #5 on: April 09, 2003, 08:17:22 pm »
well for example mr_ms pacman when i load it i get the table with scores up top but the fonts are cutt in half? as are most fonts in the tables?   when i hit setup in vpinmame and hit test hit the mspac.zip it loads just fine the little black screen. but when i go to visual  pinball and click the table ity just loads the table i just dont get this?
i have a pinball folder inside i installed visual pinball..
then i created folder inside pinball called vpinmame and placed all vpinmame stuff there.
then vbs .zip extracted to tables and i get nothing??
what you think this is driving me crazy!!
fonts are cutt up and vinmame will not load ahhhhhhhhhhh!
BobA
  • What Me Worry?
« Reply #6 on: April 09, 2003, 10:16:25 pm »
This may not help but my vpinmame and vpinball are in the same folder.
BobA
tyweed
« Reply #7 on: April 13, 2003, 06:27:25 pm »
anyone have ms mr pacman vp table when you load it do the fonts look cutt in half or is this just mine?
