Author Topic: Monitor Options ?  (Read 2279 times)
Vampyre
  • Last login:April 14, 2004, 09:19:47 am
  • Roger Roger!
Monitor Options ?
« on: April 08, 2003, 05:19:14 am »
OK i have a jamma cab that has been hacked to put a tv in it (now dead). Whats my best option ? a new tv or should i go for an arcade monitor.
I'm gona use a j-pac ,. do i need one of the 15hz video cards. the vid card i'd like to use is a tnt2u.
what do you guys suggest ?
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
Re:Monitor Options ?
« Reply #1 on: April 08, 2003, 10:16:32 am »
Get another arcade monitor with the ArcadeVGA (www.ultimarc.com), if you can afford it.  If not, any ati card with tv out and a decent tv is okay.
Now with cup beer holders!
Vampyre
  • Roger Roger!
« Reply #2 on: April 08, 2003, 10:32:16 am »
well my tnt2u has a good tv out (used to use it all the time) so i might go with that and a tv.
I cant afford the arcade vga ,. its just to much of an outlay when you add in the monitor as well.
Vampyre
  • Roger Roger!
« Reply #3 on: April 11, 2003, 10:04:38 pm »
if i buy a jpac can i then plug my normal vga into it or do i need an arcadevga card?
tom61
  • Last login:September 18, 2017, 12:46:56 am
« Reply #4 on: April 12, 2003, 05:33:18 pm »
The J-Pac video only protects the aracade monitor from being damaged by too high of sync coming from a card. You need either the ArcadeVGA card, or run DOS with utilities to get a normal card to work with an arcade monitor.
