Author Topic: Checklist before swapping PCB's?  (Read 2765 times)
Ninten-doh
  • Last login:March 31, 2017, 10:37:18 am
  • I promise sweetie, this is my last cab purchase
« on: February 28, 2007, 09:59:54 pm »
Okay, paranoid about my first real, non-MAME arcade cab. This first cab is a Turbo Outrun that I recently picked up. I have an untested Outrun board that I want to swap in. I know the boards are interchangeable, so I can just swap them out, but before I do, is there anything I should be checking on either the board or the cab?
Can the untested board do any kind of damage to the other cab components if I do something wrong, or is the worst thing that can happen be that the board simply doesn't work?
Any and all feedback appreciated!   :cheers:
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Checklist before swapping PCB's?
« Reply #1 on: February 28, 2007, 11:34:28 pm »
Do it with the power off.
NO MORE!!
Ninten-doh
« Reply #2 on: March 01, 2007, 10:06:33 am »
Yep, that part I knew about.   ;)
« Reply #3 on: March 01, 2007, 11:53:30 am »
Yes, depending on the architecture of the cab itself, an untested board can damage other components if it has flaws.  Most of the time it won't but it can happen.
Ninten-doh
« Reply #4 on: March 01, 2007, 01:58:42 pm »
Thanks for the heads up Chad.  Someone over at KLOV also told me to be ready to pull the plug on the slim chance I smell smoke.
« Reply #5 on: March 01, 2007, 02:02:10 pm »
I don't know the specific layout of that game but I'm guessing it's not that complex.  Worst likely case is the board further damaging itself.  If there are aux boards in there (e.g. like the AR boards in Atari games), that could potentially be damaged by a bad game PCB.  The power supply probably would not be and the monitor very likely would not be unless the monitor is pulling power from the game PCB for some reason.
Ninten-doh
« Reply #6 on: March 01, 2007, 03:03:25 pm »
Yep, looks pretty straightforward to me...
« Reply #7 on: March 01, 2007, 03:07:57 pm »
Looks to me like that's a multiPCB game and you can't see one underneath.  Hard to tell for sure from that pic.
Ninten-doh
« Reply #8 on: March 01, 2007, 03:15:24 pm »
Chad, it definitely is a multi PCB game.
« Reply #9 on: March 01, 2007, 03:21:53 pm »
Are you swapping out the whole set or just one?
Ninten-doh
« Reply #10 on: March 01, 2007, 04:13:21 pm »
The whole set.  Turbo Outrun is being replaced with Outrun.
paigeoliver
  • Awesome face!
« Reply #11 on: March 02, 2007, 06:06:41 am »
If the Outrun board works then take pictures and then list it on ebay as tested/working. You will be very happy with the results.
Outrun boards normally go for more than the entire game is worth. I think it is due to the fact that there are still some Outruns out there on location and it is a really popular game amongst non-techie arcade collectors.
