Author Topic: Quitting VisualPinball  (Read 1297 times)
bmrust
  • Last login:December 10, 2007, 10:32:45 am
  • PEW PEW PEW!!!
« on: February 28, 2007, 11:25:34 am »
On my cabinet, I'm not planning to have an Enter key, or Alt+F4, or anything like that...but I do want to play VisualPinball.  So far, the only way I've found to quit, is Esc, Quit to Editor, then Alt+F4 out of that...or use a mouse (which i wont have either).
Any suggestions?
Using a Keywiz 2 Eco ... but I dont have any room to add more buttons to the layout.
Tiger-Heli
    • Tiger-Heli
Re: Quitting VisualPinball
« Reply #1 on: February 28, 2007, 12:56:00 pm »
I thought Howard Casto either had a VP wrapper or a universal wrapper that would work for this.
Otherwise, I would try using AutoHotKey and a simple script that sent both "Esc" and "Alt+F4" when "Esc" was pressed and making a batch file that loaded the AHK script, loaded VP, and then unloaded the AHK script after VP exited.
