Author Topic: [AtomicFe]2 new layouts on line  (Read 3056 times)
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« on: February 27, 2007, 07:27:49 am »
Hi,
I just upload 2 new layout on my website.  These are some variant of the _shock one with some reflections.
The previous ones i uploaded  reflect only the snap ,  these versions reflect the entire screen.
Horizontal version :
Vertical version :
langdoguk
  • Last login:October 30, 2009, 03:45:23 pm
  • hey you Guys !
Re: [AtomicFe]2 new layouts on line
« Reply #1 on: February 27, 2007, 09:46:02 am »
Exactly what I like , clean and clear , easy to read the game names , and not too much going on to distract me .
Is there any way to speed up scrolling through the game list as it takes a good few minutes to get from top to bottom.
Help I'm useless !!!!
youki
    • Atomic Front End
« Reply #2 on: February 27, 2007, 10:01:34 am »
You have 2 way to speedup.
The first one is to use Left and Right to jump   :
   - a given number of game
or - Jump to the next letter
And since Atomic 0.19  there is a new option "turbo browse" , if this option is enabled if you maintain the control up or down, the list will go faster and faster...
these options are here :
FrizzleFried
    • Idaho Garagecade
« Reply #3 on: February 27, 2007, 10:06:25 am »
It's likely been asked...but is there a way to set up a SINGLE BUTTON to switch to an external program like WinCab?   On the Mala setup I am using,  I simply push a button and WinCab pops up.
youki
    • Atomic Front End
« Reply #4 on: February 27, 2007, 10:13:51 am »
Yes, you can run external command on  special event  or key press.
here :
To define what key for "custom keys"  , you use AtomicKey.exe  .
In case, If you would  need more than 3 keys ,  you can use the new plugin system.  It is easy to do.  The new plugin system is based on vbscript and plugin code can be done with a simple the notepad.  No need development tools or compilation..etc...
langdoguk
  • hey you Guys !
« Reply #5 on: February 27, 2007, 11:12:55 am »
Hi , I'm enabling page down to next letter and turbo boost but it doesn't save the changes , well it does but when I go back in there not ticked anymore  :dunno
youki
    • Atomic Front End
« Reply #6 on: February 27, 2007, 11:18:34 am »
I just tested here, it works for me.
Are you sure you press the "Save" button after having ticked the options?
langdoguk
  • hey you Guys !
« Reply #7 on: February 27, 2007, 11:30:03 am »
Hi , I can get it to save the changes but it doesn't work in the list ? The boxes are still ticked when I go back into atomic manger  :dunno
youki
    • Atomic Front End
« Reply #8 on: February 27, 2007, 11:35:34 am »
Are you using plugnplay module?  If yes  which ones?
Can you get that file :
http://www.AtomicFe.com/divers/dumpConfig.bat
copy it in Atomicfe folder , and run it.  It will generate a file  AtomicInfo.txt , send it to me on my email : y o u k i @ a t o m i c f e  .  c o m
thanks
langdoguk
  • hey you Guys !
« Reply #9 on: February 27, 2007, 11:55:18 am »
Hi , I'm using plug and play arcades simple ( like me )module .
I clicked on the link and a dos box appeared ( not got a clue about dos , sorry) saying the file has been generated press any key to continue then it dis sapears ? Had a look in Atomic FE but can't find the file.
youki
    • Atomic Front End
« Reply #10 on: February 27, 2007, 12:01:12 pm »
Ok, you are using a plug'n play module it is why.
So , run AtomicManager.exe
Click on "Load config"
Select the file  <atomicfe>\plugnplay\arcade_simple\arcades.cfg
Go on the option tab,  and tick the options you want.
Click save.
And try again.
It is because when Atomic is in plug'n play mode, it ignores the start up config. It starts on plug'n play configs.
For the .bat ,  right click on the link , choose "save target as" , save it on AtomicFE folder ,  double clique on the file , then the file should be generated in the Atomic folder.  But anyway , i don't need it for now.
langdoguk
  • hey you Guys !
« Reply #11 on: February 27, 2007, 12:27:21 pm »
Oh no , I've broke it  :cry:
done that now when I go to arcade simple it says
' no roms found ' and ' extention :zip'      , with no games list now
sorry  :dunno
youki
    • Atomic Front End
« Reply #12 on: February 27, 2007, 12:35:39 pm »
Run the Dumpconfig.bat from the AtomicFolder , this time.
And send it to me.
The causes could be :
-you modified the Rom folder settings in Arcades.cfg
-You modified the name of the roms folders on your drive
-You  deleted your roms folder
Jeff AMN
    • Gamer Theory
« Reply #13 on: February 27, 2007, 04:51:43 pm »
Heh, it looks like my decision to switch to AtomicFE is becoming easier. Later tonight I'm going to set up all the modules and give it a go.
youki
    • Atomic Front End
« Reply #14 on: February 28, 2007, 11:15:17 am »
The problem Langdoguk had , has been fixed by the patch i just put online.
thanks to him to highlight me that problem.  :cheers:
millercentral
  • Last login:March 07, 2024, 04:38:47 pm
« Reply #15 on: February 28, 2007, 12:55:08 pm »
Can atomicFE change orientations based on which controls are selected?
langdoguk
  • hey you Guys !
« Reply #16 on: February 28, 2007, 02:03:38 pm »
Working great now , thought it was just me  , had been trying to get the favorites list going for months and this sorted everything , cheers  :cheers:
youki
    • Atomic Front End
« Reply #17 on: March 01, 2007, 06:47:09 am »
No, but it can change orientation based on which game is selected.  I suppose control depends on the game.
edit:
Are you asking for a coktail table?  Because Atomic has a coktail mode.  If you press a button, it rotate the screen to the other player and the other player takes the control.  But it is not automatic, you have to press un button.
« Last Edit: March 01, 2007, 07:00:49 am by youki »
