Author Topic: Jukebox skin and album cover size  (Read 3723 times)
tylergreenwood
  • Last login:February 27, 2007, 01:28:08 am
« on: February 26, 2007, 03:06:43 am »
I went back to the beginning of the forum and didn't find anything on this.  I'm just wondering if there is any way to make the album covers scale down without squishing them horizontally.  Right now it looks like they're being scaled down by 50% vertically and 55% horizontally (just random percentages to demonstrate my point) and resulting in rectangular covers instead of square.  The other problem this poses is that any rectangular album covers (ie: digipaks, singles, taller cases) are horribly out of shape and they look really bad.  Is there any way to make it scale them to, perhaps, a certain width and then scale them vertically in relation to that?  Say it has to scale down from 500 pixels to 250 pixels horizontally (50%) so then it scales the vertical pixels to 50% as well.
MrD
  • Last login:May 20, 2020, 04:34:05 pm
Re: Jukebox skin and album cover size
« Reply #1 on: February 26, 2007, 08:18:45 am »
My guess is that the aspect ratio is off.  I think it's in jukebox.ini, right near the top (as I recall).  I'd try changing that and see if it makes a difference.   That's just a guess mind you, but I think it affects how the images are adjusted.   I'm sure Chris will be much more helpful on this matter.
Chris
  • Moderator
    • Chris's MAME Cabinet
« Reply #2 on: March 05, 2007, 10:57:15 am »
Album covers are always stretched to a perfect square after adjusting for aspect ratio, so yes, rectangular images will end up looking bad.  MrD is probably right that the aspect ratio overall is not set correctly for you.  If you have a widescreen monitor you need to calculate your aspect ratio and set MonitorAspectRatio in jukebox.ini to that value.  For example, if you have a 16:9 monitor, your aspect ratio is 16 divided by 9 or 1.777.  Thus, you would have MonitorAspectRatio=1.777 in jukebox.ini.
--Chris
--Chris
