Author Topic: My spinner panel position  (Read 1684 times)
Derrick Renaud
  • Last login:December 06, 2024, 04:31:44 pm
« on: February 24, 2007, 09:48:19 pm »
FWIW, my panel layout is the standard 7 button Hotrod style layout.  I removed the lowest button below/left of the other 6 buttons and installed a TurboTwist2 there for each player.
It does not get in the way of the buttons or joystick.  It makes it easy to play Ikari-type, Boot Hill, Tron, etc.  I use my thumb on the hand I control the buttons with to roll the edge of the spinner and can still easily control the buttons.
I have not tried DOT yet, but I think it would work for that too.  Just set the two right buttons as up/down.
While obviously not the same as the original controls. it does make the games quite playable.
D.
fjl
  • Pixels Rule!
Re: My spinner panel position
« Reply #1 on: February 24, 2007, 10:01:50 pm »
pix pls
That actually sounds like a good idea although I wouldn't want to lose my 7 button layout.
« Last Edit: February 24, 2007, 10:07:10 pm by efjayel »
Derrick Renaud
« Reply #2 on: February 25, 2007, 12:11:42 am »
pix pls
Can't afford beer and a camera.  Can't program without beer.  Therefore no camera.
I never used the button myself.  I don't play fighters or neogeo games that use a 4 button layout.  You might be able to squeeze the 7th button in above the spinner, in the middle and to the left of the 2x3 button layout.  I might actually do that if it will fit.  Joystick might be too close.
D.
fjl
  • Pixels Rule!
« Reply #3 on: February 25, 2007, 12:57:33 am »
I want pix! :hissy:
