Author Topic: Need help with trigger sticks  (Read 2071 times)
Tony Bag O Donuts
  • Last login:March 22, 2009, 07:30:34 pm
« on: April 07, 2003, 09:14:28 am »
Hey all.  I just installed two trigger sticks into my control board using two PC Raider Pro joysticks hacked to fit into a Happs Super Joystick base.  I haven't figured out a good way to keep the joysticks from twisting.  Anybody got a good idea how to work this out?
shmokes
  • Don't tread on me.
    • Jake Moses
Re:Need help with trigger sticks
« Reply #1 on: April 07, 2003, 11:35:03 am »
Best Kid iPad Apps
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: April 08, 2003, 01:36:14 am »
All I did was wrap a total of ~5 layers of clear packing tape around the lower half of the shaft.  The sticks can still turn if forced, but you need a good twist to do so.  I had to wrap each stick differently depending on stuff like if there were any wrinkles or not.  This also helped shim the shaft and get rid on the very slight loose-ness of the stick in the controller and added a small amount of padding.
NOT recomended if you have 6-14 year kids, though, because they might just twist and twist and twist and mess up the wiring. :P
Robin
Knowledge is Power
Tony Bag O Donuts
« Reply #3 on: April 11, 2003, 01:52:42 am »
Great ideas.  Thanks.
