Author Topic: Jamma question  (Read 2640 times)
razzerx
  • Last login:December 24, 2020, 10:26:09 am
Jamma question
« on: February 22, 2007, 09:59:14 pm »
I was just given a complete working Black Tiger arcade and was wondering since its jamma and I can swap out PCBs I'd like to add a few extra buttons for different games. So what exactly do I need?
johnm160
  • Last login:April 09, 2024, 09:00:46 pm
Re: Jamma question
« Reply #1 on: February 23, 2007, 08:44:26 am »
the easiest way would be to order a multi jamma kit that allows you to switch between games without having to open the cabinet
Something like this.
http://www.multigame.com/jamma.html
razzerx
Re: Jamma question
« Reply #2 on: February 23, 2007, 09:55:59 am »
That will work but I still want to add some more control for games that need them.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Jamma question
« Reply #3 on: February 23, 2007, 09:04:17 pm »
First thing you need to know is what JAMMA includes -- one joystick and three buttons for two players. Anything else (e.g. more than 3 buttons) is not on the JAMMA harness and requires additional wiring (often called a kick harness) that will be different from game to game.
http://www.coin.demon.co.uk/jamma.htm
NOTE: OK, some games will pick up Button 4 from the harness, but that varies from game to game.
Check out the games at you want to play and se what the wiring implications are.
Cheers
« Last Edit: February 23, 2007, 09:06:04 pm by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
razzerx
Re: Jamma question
« Reply #4 on: February 24, 2007, 05:10:33 am »
Iwas looking at a 48 in 1 pcb. Do you think you could add a trackball for centipede?
CheffoJeffo
Re: Jamma question
« Reply #5 on: February 24, 2007, 07:24:42 am »
Get a copy of the pinouts for the PCB ... I beleive the 48-in-1 has pins on the board for a trackball.
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
razzerx
Re: Jamma question
« Reply #6 on: February 24, 2007, 08:06:23 am »
I looked into it and I guess it dosnt support a trackball yet. Maybe I'll look into a cps 2 setup. It seem like game carts are pretty cheap.
« Last Edit: February 24, 2007, 08:26:54 am by razzerx »
