Author Topic: Happs Ultimate 4-way  (Read 1902 times)
BLah247
  • Last login:June 12, 2014, 08:01:53 am
« on: February 13, 2007, 04:25:07 pm »
Have a question on reading the schematic from Happs..
I'm installing this on in a wood control panel and plan to have it only do 4-way.
So I use either 95-1308-00 for wood or 95-1306-00 for metal?
Then do I use 95-1307-00 in place of 95-0267-00 for the 4-way?
Them seems simple enough but when I put it together using the 95-1308-00 spacer and the 95-1307-00 actuator it's not smooth at all with the movement and the actuator only touchs maybe one of the cherry switches.
Oh and oddly enough I broke the c-clip 95-0574-00... anyone know a suitable replacement from a big box retailer?
BLah247
Re: Happs Ultimate 4-way
« Reply #1 on: February 13, 2007, 04:26:06 pm »
http://www.happcontrols.com/images/50/50760800_exploded.gif
There's the actual link... the embedded image is hard to read.
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« Reply #2 on: February 13, 2007, 06:46:14 pm »
Go to Ace hardware I'm sure they will have one that works.
Knievel
    • Knievel Kustoms
« Reply #3 on: February 14, 2007, 11:16:15 pm »
Hmm..did you actually order a 4-Way Ultimate?
I know it has a specific part# compared to the 8-way, and looking at the diagram there are 3 part#'s for the bases so the 4-way base must be different than the 8-way.
I've never had an issue with one not fitting together well.
BLah247
« Reply #4 on: February 15, 2007, 11:27:36 am »
It should be the 4-way... It came with the 4-way actuator and the base of it looks as if it's groved in a manner to only allow the stick to move in four ways.  Should I maybe use the 95-1306-00 part instead of the 95-1308-00 part?  I think that will just make the joystick shorter though and not affect anything else.
