Author Topic: Tee-nuts : What size ?  (Read 1670 times)
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« on: February 10, 2007, 10:00:19 pm »
Quick question:
 What size T-nuts for mounting joysticks in 5/8 MDF would one be wise to use ? http://www.mcfeelys.com/subcat.asp?sid=187
johnm160
  • Last login:April 09, 2024, 09:00:46 pm
Re: Tee-nuts : What size ?
« Reply #1 on: February 11, 2007, 10:57:27 pm »
You need to figure out what size screw will fit through the hole in your joystick mounting plate to answer this.
Can you fit a 1/4 screw through it or only a 10-24?
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #2 on: February 12, 2007, 08:40:54 am »
10-24 can be used on almost anything.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: February 12, 2007, 10:07:51 am »
10-24 is standard for use in America.
tommyinajar
« Reply #4 on: February 12, 2007, 11:21:13 am »
10-24 it is then, comrade ! Thanks :)
moriartyds
  • Last login:November 05, 2007, 09:09:39 pm
« Reply #5 on: February 12, 2007, 03:07:43 pm »
I picked up some 10-24 x 5/16" (I believe) at Home Depot along with some 10-24 1/2" machine screws (note:  I used 3/4" wood but routed out a recess for the joysticks).  So far so good.
tommyinajar
« Reply #6 on: February 12, 2007, 03:30:21 pm »
Yea I looked at Home Depot I think they wanted 4 or 5 bucks for 4 of them !!
 That seems ridiculous when I can get 50 of them from http://www.mcfeelys.com/ for like 10 bucks.
moriartyds
« Reply #7 on: February 12, 2007, 03:50:52 pm »
Wow, that's crazy.  I picked up the 12 t-nuts (4 per package) and a packet of bolts and I could have sworn I only paid like $7-8.
Still, can't beat the price online.  Plus you have plenty to work with should things go wrong ... err, should you build multiple CP's.
