Author Topic: MsgexecCmd error in Mamewah  (Read 1630 times)
govee
  • Last login:February 19, 2012, 09:26:30 pm
« on: February 09, 2007, 08:56:51 am »
Mame 61 and mamewah V1.62, Win98SE. I was having video problems that would not resolve so I used my old standby, Format C:. Now have a fresh load win98 as well as mame and mamewah. All video problems are gone but I am having no luck with list generation. I have changed the mame.ini to reflect _listinfo. Here are my .ini's and my log file. Games work when launched from cmd line pmt.
2/9/07 8:36:44 AM MAMEWAH v1.62 launched
2/9/07 8:36:44 AM Desktop colour: 8421376
2/9/07 8:36:44 AM Wallpaper filename:
2/9/07 8:36:44 AM Desktop display mode: 800x600 @ 60Hz, 16bit colour
2/9/07 8:36:44 AM Decimal symbol: '.'
2/9/07 8:36:45 AM Games list read: mame-0.lst
2/9/07 8:36:45 AM Layout selected: C:\MAMEWAH\config\layout.lay
2/9/07 8:36:45 AM No. joystick devices attached: 0
2/9/07 8:36:45 AM Ctrlr file selected: C:\MAMEWAH\config\mamewah.cfg
2/9/07 8:36:45 AM Keyboard enabled
2/9/07 8:36:48 AM List generation started...
2/9/07 8:36:48 AM List generation aborted
2/9/07 8:36:48 AM Games list read: mame-0.lst
2/9/07 8:36:52 AM MAMEWAH quit
mame.ini### mame.ini (mamewah v1.62) ###
emulator_title                            M.A.M.E.
### List Generation Settings ###
rom_path                                  c:\mame\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder_vs_listinfo
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      c:\mame\mame.exe [name]{nodosbox}{nosafelaunch}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       auto:[emuexepath]\snap;[emuexepath]\titles;[emuexepath]\marquee;[emuexepath]\control;[emuexepath]\cabinet;[emuexepath]\flyers;[emuexepath]\boxart;[emuexepath]\cart;[emuexepath]\art9;[emuexepath]\art10
movie_preview_path                        c:\mamewah\config
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file                          auto
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                slideshow
movie_path                                c:\Mamewah\config
movie_fullscreen                          1
quit_delay                                0
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
mame-0.ini
### mame-0.ini (mamewah v1.62) ###
list_title                                All Games
### Games List Settings ###
cycle_list                                1
current_game                              0
mame-1.ini
### mame-1.ini (mamewah v1.62) ###
list_title                                Favorites
cycle_list                                1
list_type                                 normal
display_clone_info                        0
max_favorites                             0
current_game                              1
Re: MsgexecCmd error in Mamewah
« Reply #1 on: February 09, 2007, 09:21:50 am »
Is this v1.62b13? (I think it is)?  If so, then try v1.62b13a - I uploaded this at the Mamewah board a few days ago.
Also, where did you get the MsgExecCmd error from?  It doesn't show in the log...
govee
« Reply #2 on: February 09, 2007, 10:18:01 am »
sorry I had cut out the line for a google search before copying it to here. I have v1.62b13 so I will try a.
2/9/07 10:16:06 AM MAMEWAH v1.62 launched
2/9/07 10:16:06 AM Desktop colour: 8421376
2/9/07 10:16:06 AM Wallpaper filename:
2/9/07 10:16:06 AM Desktop display mode: 800x600 @ 60Hz, 16bit colour
2/9/07 10:16:06 AM Decimal symbol: '.'
2/9/07 10:16:06 AM Games list read: mame-0.lst
2/9/07 10:16:06 AM Layout selected: C:\MAMEWAH\config\mame\\layout.lay
2/9/07 10:16:07 AM No. joystick devices attached: 0
2/9/07 10:16:07 AM Ctrlr file selected: C:\MAMEWAH\config\mamewah.cfg
2/9/07 10:16:07 AM Keyboard enabled
2/9/07 10:16:14 AM List generation started...
2/9/07 10:16:14 AM Error: 76 Path not found in MsgExecCmd
2/9/07 10:16:14 AM List generation aborted
2/9/07 10:16:14 AM Games list read: mame-0.lst
2/9/07 10:16:20 AM MAMEWAH quit
jcrouse
    • CPViewer
« Reply #3 on: February 09, 2007, 10:27:06 am »
Try {autodosbox} instead of {nodosbox}. May not fix this issue but I believe that is correct for that version of mame/mamewah.
John
govee
« Reply #4 on: February 09, 2007, 10:39:29 am »
Ok, I tried the n"a" version and tragically still fails. here is the new log.
I also change to autodosbox with no joy.
2/9/07 10:35:12 AM MAMEWAH v1.62 launched
2/9/07 10:35:12 AM Desktop colour: 8421376
2/9/07 10:35:12 AM Wallpaper filename:
2/9/07 10:35:12 AM Desktop display mode: 800x600 @ 60Hz, 16bit colour
2/9/07 10:35:12 AM Decimal symbol: '.'
2/9/07 10:35:13 AM Games list read: mame-0.lst
2/9/07 10:35:14 AM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
2/9/07 10:35:14 AM Layout selected: C:\MAMEWAH\config\layout.lay
2/9/07 10:35:14 AM No. joystick devices attached: 0
2/9/07 10:35:14 AM Ctrlr file selected: C:\MAMEWAH\config\mamewah.cfg
2/9/07 10:35:14 AM Keyboard enabled
2/9/07 10:35:18 AM List generation started...
2/9/07 10:35:18 AM Error: 76 Path not found in MsgExecCmd
2/9/07 10:35:18 AM List generation aborted
2/9/07 10:35:18 AM Games list read: mame-0.lst
2/9/07 10:35:26 AM Mode 800 x 600 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
2/9/07 10:35:27 AM MAMEWAH quit
jcrouse
    • CPViewer
« Reply #5 on: February 09, 2007, 10:49:51 am »
Change it back to {nodosbox} for the latest beta.
John
