Author Topic: Help wwith Gameex please  (Read 1416 times)
Panzer
  • Last login:December 05, 2008, 08:04:25 pm
« on: February 06, 2007, 03:22:53 pm »
Hi all,
For what ever reason my X-arcade controler Joy 1 kept getting stuck when the keys were set to the num pad. So i went ahead and reprogrammed them to
up=h
Down=j
Left=k
Right=l
Now the controller works great but apparently those keys are set as defaults for Game Ex as well and when I try to control in a game with Joy 1 the thing goes all screwy.
So my question is... caan i change somewhere the default keys of Game ex?
Or what keys other than tthe num pad cann  i set the joy 1 as tto not inter fear wwith Game Ex.
(Sorry i tried to post on thier forum but it would allow me to create a user ID.)
Thanks all!
meltman
  • Last login:April 02, 2025, 11:06:11 am
  • Brilliant!
    • forum.arcadecontrols.com/index.php/topic,158544.0.html
    • My arcade gallery
Re: Help wwith Gameex please
« Reply #1 on: February 06, 2007, 03:37:51 pm »
You can define custom keys in gameex in either the setup wizard or advanced configuration.
Its in the "input" tab.
Panzer
« Reply #2 on: February 06, 2007, 03:47:22 pm »
When I go to change the custominput ini i  get this...
[KEYBOARD]
#Scan Code Number
# See Scancodes.txt for a list of Scan Codes specific to your system.
# If file not there, run GameEx.
Select=30
Back=48
Shift1_Paging=46
Shift2_Volume=32
up=200
down=208
left=203
right=205
PrevTrack=44
NextTrack=45
Home=199
[JOYSTICK]
#Button Number starting a 0
Select=0
Back=1
Shift1_Paging=3
Shift2_Volume=4
PrevTrack=6
NextTrack=7
Do i just replace those values with the corresponding letters?
For example change up=200 to  up=h ?
Thanks again
FrizzleFried
    • Idaho Garagecade
« Reply #3 on: February 07, 2007, 03:31:22 pm »
Same here...and when you compare the values in that config file with the values listed in scancodes.txt,  they do not match!
For example,  it lists SELECT=30,  30 is NOT player 1 button...but player 1 button does,  indeed,  select.   Back is listed as 48,  but according to scancodes.txt,  48 does not equal the button that BACK is assigned to stock...so I am confused as all hell.
