Author Topic: All wired up and configuring the Ipac! But i need a little help!  (Read 1987 times)
bsoder52
  • Last login:June 24, 2025, 11:29:40 pm
 :o ??? 8) ::) :) ;) :D ;D
OK, getting super pumped up!
I almost have this control panel up and running!
Here is where I'm stuck:
I can't assign values to the 1st player joystick for some reason, i can assign keystrokes, but not up, down, right, left?????????????????????/  Any ideas?  I have the PL2 joystick up and running like a champ.
Also there are a couple buttons for PL2, that I'm having trouble assigning for the six button "Street Fighter" configuration, any help here would be extremely appreciated as well.
Thanks in advancE!
Bsoder52
radiator
  • Last login:April 18, 2013, 07:14:43 pm
  • SFA OK!
    • :: verticalcircle ::
Re:All wired up and configuring the Ipac! But i need a little help!
« Reply #1 on: April 04, 2003, 02:28:05 pm »
i too had the arrow key problem
just turn off NumLock and use the number keypad to assign the controls (ie, 2=down, 4=left, 6=right, 8=up)
that should work
*m
When the Germans bombed the British, the British ducked.
When the British bombed the Germans, the Germans ducked.
When the Americans started bombing, everyone ducked!
_Iz-
  • Last login:Yesterday at 10:41:02 am
  • Time to coin up!
« Reply #2 on: April 04, 2003, 03:56:33 pm »
How are you trying to program the IPac? (what program?)
bsoder52
« Reply #3 on: April 04, 2003, 05:47:04 pm »
Downloaded the WinIpac from the Ultimarc website.
_Iz-
  • Time to coin up!
« Reply #4 on: April 04, 2003, 05:51:03 pm »
You could always try the built-in programming method. Just load the default config first (it will give you arrow keys for joy 1 directionals) then program the others to suit...
bsoder52
« Reply #5 on: April 06, 2003, 12:19:19 am »
Man, nothing is working for me!
I tried loading up the (2,4,6,8) keypad with numbers lock off and that didn't work for me.
I loaded up the Winpac configuration file and that put the Up,down, right, and left commands into the WINPac programming screen for the 2plr joystick, but when I run Mame, the PL2 Joystick controls Pl1???????????
Wierd!
I have PL1 up and running perfect, but anymore advise to get my PL2 stick going would be fantastic!
Thanks in advance!
bsoder52
« Reply #6 on: April 06, 2003, 12:40:29 am »
Actually just figured it out.  I used the default controls off the UltiMarc website.  It's always best to read the instructions after you have exausted all possible means of figuring it out on your own
