Author Topic: max number of ps2 devices...?  (Read 1221 times)
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« on: February 02, 2007, 01:43:28 pm »
correct or incorrect...?
you can only use one ps2 device at a time per port...
meltman
  • Last login:April 02, 2025, 11:06:11 am
  • Brilliant!
    • forum.arcadecontrols.com/index.php/topic,158544.0.html
    • My arcade gallery
Re: max number of ps2 devices...?
« Reply #1 on: February 02, 2007, 01:46:34 pm »
only one at a time.
RandyT
  • Last login:Yesterday at 01:39:00 pm
    • GroovyGameGear.com
« Reply #2 on: February 02, 2007, 01:50:47 pm »
Ummm....it depends?
If such a device existed (it may, I don't know), a "hub" is theoretically possible.  It would act as a traffic controller for multiple devices.   Similarly, a "pass-through" device could be chained for the same end result, but would impose delays proportionate to the position of the device in the chain.
But if you are talking about hooking 2 keyboards to a single PS/2 port with a simple passive splitter, no, it won't work.
RandyT
fixedpigs
« Reply #3 on: February 02, 2007, 01:56:18 pm »
i'm trying to figure out what devices i am going to get should be ps/2...
tt2/ice trackball/ledwiz/keywiz are all in my immediate future...but i'm getting all confused on when i should be using ps/2 versus usb and also the device numbering with each of the ggg components...
i actually sent you a pm randy...-=)
