Author Topic: Is it possible to display a VGA signal on an RGB Monitor?  (Read 2914 times)
albert_c
  • Last login:April 06, 2010, 03:57:07 pm
« on: February 01, 2007, 03:42:20 pm »
I've asked a couple of people and I got mixed answers.
This is what I want to do:
I have a Standard Resolution 36" Arcade Monitor.  It's currently displaying the Sega Dreamcast in 15khz standard resolution.  Looks real nice but the games I want to play on it should be running in VGA mode.  So, when I look at the monitor I want it to look like VGA.
Someone suggested the XRGB, can anyone confirm that it would work?
Is there a device I can use to make  my Standard Resolution monitor output VGA, and look like VGA with little or no signal degradation.
Albert
« Last Edit: February 01, 2007, 03:49:34 pm by albert_c »
Kevin Mullins
    • Me on Myspace
Re: Is it possible to display a VGA signal on an RGB Monitor?
« Reply #1 on: February 01, 2007, 04:19:40 pm »
No....
Because a monitor doesn't "output" anything.  ;D
Seriously though.... if you have a standard resolution monitor, then it will only accept a standard resolution "input". (CGA)
You would have to adjust, either by hardware or software, whatever it is you want to display on the monitor down to 15khz. (standard resolution)
What monitor are you using?
albert_c
« Reply #2 on: February 01, 2007, 05:10:57 pm »
I think it's a WG, it does CGA and EGA.  What if I put a VGA chassis in there?
Kevin Mullins
    • Me on Myspace
« Reply #3 on: February 01, 2007, 06:39:21 pm »
It would more than likely instanly cook your VGA chassis unless you have the matching yoke to go with it.
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #4 on: February 01, 2007, 08:02:10 pm »
I I understand your question right, you want to run VGA games (640X480 @ 31khz). If so I  may have the solution??
Just brought in a couple of converters that may do the Job, but it would mean that you have to manualy change your signal connections each time.
Have not yet completed the testing.
Too bad you don't have our tri-mode 39"
Rick Nieman
Nieman Video Displays
Niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
albert_c
« Reply #5 on: February 02, 2007, 01:33:41 pm »
Yes, I want to run VGA games at 640x480 at 31khz.  But when I look at the monitor I want it to LOOK like VGA, not CGA.  What do these converters do/look like.  Manually change the signal everytime I turn the monitor on or every time I want to go from CGA to VGA?  I don't need CGA for this monitor.
I would kill for your tri-mode 39"  I probably can't afford it for this project.
tetsu96
  • Last login:September 06, 2024, 12:00:03 pm
  • MAME On...
    • My Old Cabinet / MAME32 build site
« Reply #6 on: February 02, 2007, 05:35:47 pm »
If you want a monitor that looks like a VGA monitor, you need to get a VGA monitor.  Upscalers and downscalers are nice and all but you won't magically double the scan range of a std res monitor with a converter.  15KHz won't look like 31KHz.
If you need a cheaper monitor, look for the Gateways or similar large CRTs that support VGA or SVGA.
Kevin Mullins
    • Me on Myspace
« Reply #7 on: February 02, 2007, 05:45:19 pm »
Agreed..... any kind of "converter" is going to do just that.... convert the VGA signal "down" to the CGA signal.
So all in all what you will have on screen is a CGA resolution.
falcons7
  • Last login:May 10, 2015, 11:47:48 pm
« Reply #8 on: February 26, 2007, 11:11:46 pm »
this may be the wrong place to post this.... but how did you connect your dreamcast to arcade monitor... i know i have to use a hacked vga box. which i have. although from then on.... i am really not sure from the vga cable to my monitor what to do... if you could post at this link to my thread i would appreciate it. thanks
http://forum.arcadecontrols.com/index.php?topic=63646.msg634868#msg634868
northerngames
  • Trade Count: (+18)
« Reply #9 on: February 27, 2007, 04:29:03 pm »
dl-36 it is a gateway 36" vga max res of 600X800 or a $200.00+ conversion kit is the only thing I could suggest.
