Author Topic: Happ 19" Vision Pro  (Read 2247 times)
sfrascella
  • Last login:September 21, 2017, 09:44:15 pm
Happ 19" Vision Pro
« on: February 01, 2007, 01:31:13 pm »
I just got a Happ 19" Vision Pro monitor for my Defender project, and the installation looks pretty straight forward but I wanted to run it by the group first before I do anything that could possibly damage it. It looks like I connect the red, green, blue, ground, v-sync, and h-sync to the corresponding pins on the board and then power it up.
Is this the case or am I missing something here? I know this is a total noob question, but this is the first time I have installed one of these.
Thank's for any help or advice.
« Last Edit: February 01, 2007, 04:17:14 pm by sfrascella »
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Re: Happ 19" Vision Pro
« Reply #1 on: February 01, 2007, 09:08:04 pm »
Just Browsing, but before you plug it in- look for stickers or warnings... IS AN ISOLATION TRANSFORMER REQUIRED!!
If so make sure you use it or you will blow fuses, regulators...
Good Luck
Nieman Video Displays
Niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
sfrascella
« Reply #2 on: February 01, 2007, 09:29:57 pm »
Thanks Rick, no isolation transformer is required with this one. I installed it tonight and it works perfectly. It actually was pretty easy, but since I had never done it before I was a little nervous.
