Author Topic: Will Home Depot Cut MDF?  (Read 11405 times)
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« on: April 03, 2003, 11:38:28 pm »
Okie, strange question... Will Home Depot (or Loews, etc...) cut MDF for you? If so, will they actually cut it into the needed pattern/dimensions for you?
My line of thinking is that I lack the space (rather, I lack the willingness of my spouse to give up the space) to do the major cutting for my cab, so could I give them the dimensions/plans for the sides of my cab and have them cut it? Does it cost a lot to have them do such a thing?
I ask this question, with the given that I would be purchasing the raw MDF from Home Depot.
« Last Edit: April 03, 2003, 11:39:24 pm by shawnzilla »
BobA
  • What Me Worry?
Re:Will Home Depot Cut MDF?
« Reply #1 on: April 03, 2003, 11:51:19 pm »
In my experience they will make staight cuts only.  You can plan your cuts to get major pieces but they use a panel saw and cannot make cuts other then vertically or horizontally on a sheet of MDF.  You can get the major parts of of cocktail cab with these cuts but not an upright cab.
A smaller customer friendly lumber yard might work something out with you but the major chains will not.
BobA
hyiu
    • www
« Reply #2 on: April 04, 2003, 12:21:34 am »
beware.... Home Depot.... most of them only do straight cuts.... and my experience is... their cut is not very accurate in length....
I have asked them to cut for me before... and they do measure it... but somehow... it turns out its a little short....
and I have to alter my sizing afterwards....
bad experience....
YMMV... good luck....
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #3 on: April 04, 2003, 12:56:21 am »
The cuts they do are rough cuts.  You can't count on them getting any closer than 1/2 inch.
You won't find anywhere that will cut out an upright cabinet side.
This opinion was created from 100% post consumed information.
SNAAAKE
  • -Banned-
« Reply #4 on: April 04, 2003, 12:58:44 am »
bad experience....
same here..they cut like crap..NOT ACCURATE..because we are in the same city and might have went to the same home depot.. :P.
I suggest you cut the whole thing yourself.. :)
Another funny thing..
My local home depot DONT cut particle board..the guy down there claims that particle board releases poison gas/fume or somethin..
WTF !  ???
Any input on this weirdness(or rather bull$hit) anyone ?
« Last Edit: April 04, 2003, 01:01:43 am by SNAAAKE »
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #5 on: April 04, 2003, 02:13:38 am »
bad experience....
WTF !  ???
it's absolutely true. OSHA will come down hard on a lumber yard that cuts particle Board /MDF without proper ventalation. The boards have formaldehyde in the wood. Very nasty to inhale. I worked at a local lumber yard in high school and people would go ape ---steaming pile of meadow muffin--- when we told them we couldn't cut their particle board. (we didn't even carry MDF)
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #6 on: April 04, 2003, 04:12:38 am »
It's absolutely true. OSHA will come down hard on a lumber yard that cuts particle Board /MDF without proper ventalation. The boards have formaldehyde in the wood. Very nasty to inhale. I worked at a local lumber yard in high school and people would go ape ---steaming pile of meadow muffin--- when we told them we couldn't cut their particle board. (we didn't even carry MDF)
I heard MDF releases more formaldehyde per cut than particle board.  Is that true?
Robin
Knowledge is Power
MilitiaMan
  • Last login:May 28, 2011, 09:25:35 am
  • It's a fine line between hobby and mental illness.
« Reply #7 on: April 04, 2003, 09:57:42 am »
Can anyone tell me more about this? I have been sanding the hell out of MDF for about a week now and I am certain that I have been inhaling particles as sanding MDF is messy as hell and creates a fine "dust" over everything near your project.
I have been smart enough to do this outside in the driveway so as not to create a huge mess in the garage, but I was not intelligent enough to wear a mask over my mouth and nose.
Should I be worried? I realize anyone replying to this likely is not a doctor and if I get really concerned I will see my physician, but any input or experience you might be able to share would be appreciated.
-MM
AX
  • Last login:April 20, 2004, 02:07:53 pm
  • The only way to win is to cheat!
« Reply #8 on: April 04, 2003, 10:07:26 am »
same here LOL.  no wonder I have had a sore throat and feel like crap.  maybe im dieing.
shawnzilla
« Reply #9 on: April 04, 2003, 12:12:16 pm »
Distortion
  • Last login:June 10, 2016, 04:39:20 pm
  • Saints Row 2, Sucka
    • Volition
« Reply #10 on: April 04, 2003, 01:14:45 pm »
Yeah, I didn't learn about the formaldahyde until after I had finished my cabinet.  I did the whole thing in my garage, which most of the time I had the door open, but sawdust was EVERYWHERE!  I got a rash from it on my arm and a little chest congestion, but I also had a cold at the same time, so some of that was attributed to my cold.
Game programmers do not play games for a living.  Would you say a mechanic drives cars for a living?
Wade
  • Last login:March 08, 2026, 03:31:11 pm
  • 80's Child
    • Wade's Gameroom
« Reply #11 on: April 04, 2003, 01:20:55 pm »
Wow, I like the second link.  Makes me feel a little better about how much of that stuff I inhaled when making my cabinet.  I am definitely going to invest in a dust collector and mask for my next big wood project though.  If nothing else, it will keep me from having to clean up my workroom as much.
Wade
MilitiaMan
« Reply #12 on: April 04, 2003, 02:15:25 pm »
Looks like I'll ~probably~ live.
Thanks for the linx.
-MM
SNAAAKE
  • -Banned-
« Reply #13 on: April 04, 2003, 03:44:39 pm »
okay so this is true  !  :o
I actually wear a mask all the time for this kind of work anyways..even solding..never know.. ;)
Anyway...atleast now I know WHY home depot didnt wanna cut it..whatever :P
shawnzilla
« Reply #14 on: April 05, 2003, 09:22:35 pm »
I found a definitive answer about the safety of cutting MDF at this link
https://answers.google.com/answers/main?cmd=threadview&id=186491#a
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #15 on: April 06, 2003, 06:39:33 am »
I just found this tidbit about MDF safety on the web.
http://www.bbc.co.uk/homes/glossary/glossary_m.shtml
http://www.safety.ed.ac.uk/resources/occ_hygiene/hygiene_update14.html
Thanks for the info, shawnzilla for this and your later link.  Good stuff to know.
Robin
Knowledge is Power
