Author Topic: Are there any REAL arcade monitors that can plug straight into a PC/video card?  (Read 2127 times)
Arcade82
  • Last login:November 01, 2008, 06:40:56 pm
I'm referring to a standard video out (whatever it may be) on video cards on a PC.
I want the authentic experience, just wondering if you could buy a real 27" arcade monitor from like Happs that will work with the computer automatically
"Yeah... at least he built a cabinet. I can't wait to see yours. "
aahahahaa
blueznl
these days there may be
i just found an old tatug that claims to be a vga monitor, haven't tried it yet...
grantspain
most manufacturers now make multi sync monitors(automatically search for the frequency input),these plug direct into the vga out of a graphics card
some i know of are betson,hantarex,wells gardner
there is a guy who posts on this forum called rick nieman(nieman displays) who i believe can supply this type of monitor,it may be worth while sending him a pm
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Yes, Grant is right, I offer a tri-mode monitor in 24.*", 27" and 39".
This monitor will accept CGA (Standard) , Mid Res (24.3 Khz) and VGA 31Khz 640X480
all with a flat tube.
Also a 27" that will do as high as 1024X768.
Feel free to contact me for more info.
Rick Nieman
Nieman Video Displays
Rick@niemandisplays.com
website: Niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
StephenH
Yes, Several.   There are some made by Nieman, Billabs, Happ Controls, Betson, and others that allow both PC and Arcade Resolutions that will plug into a VGA port.  Here are some important things to know:
* Standard Res - 15Khz (CGA) - most MAME raster games run at this resolution (200-300 vertical pixels)
* Medium Res - 24Khz (EGA) - Used for a few arcade games ((301-405 vertical pixels)
* High Ress - 31Khz (VGA) - Used for entry level PC graphics, and some newer arcade games (406-480 vertical pixels) - 640x480 mode is common
* SVGA Res (SVGA) - 38Khz - Used for Windows and PC Graphics (600 Vertical Lines) - for example 800x600 mode
* XGA Res (48Khz) - Used for PC Graphics up to 1024x768
Try to get a monitor that will run the modes you want to run.   Please note that to run at 15Khz or 25Khz, you need a video card that can run at these resolutions.
