Author Topic: I'm so terribly confused!!! (ArcadeVga + ipac/jpac)  (Read 1877 times)
sphetr2
  • Last login:February 08, 2009, 06:35:00 pm
  • black and white album
« on: January 25, 2007, 05:25:56 pm »
I thought I knew exactly what to do until I went to the Ultimarc website. I was just going to get an ArcadeVGA + ipac for my JAMMA cab (i'm not actually using the Jamma controls).
But Utlimarc says "you need a video amp nyar nyar nyar!!!"
So. Is this true? If so, should I get a jpac instead of an ipac? Or do i not need amplification?
Also, will jpac support more than 3 buttons per player? Cause last time I checked that was JAMMA's limit (not sure though- and not sure if that translates to the jpac).
Thanks.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: I'm so terribly confused!!! (ArcadeVga + ipac/jpac)
« Reply #1 on: January 25, 2007, 05:33:13 pm »
VideoAMP -- I hve never needed one (well, not sure for some since I used J-Pacs), but know people who have (and bought the ones I previously ordered). When in doubt, tell Andy what kind of monitor you have.
The J-Pac "supports" 8 buttons per player (buttons 4-8 on screw terminals).
http://www.ultimarc.com/jpac1.html
Cheers.
EDIT: FWIW, if you have an intact JAMMA harness, I would choose a J-Pac over an I-Pac2 everytime.
« Last Edit: January 25, 2007, 05:36:48 pm by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
meltman
  • Last login:April 02, 2025, 11:06:11 am
  • Brilliant!
    • forum.arcadecontrols.com/index.php/topic,158544.0.html
    • My arcade gallery
« Reply #2 on: January 25, 2007, 05:34:59 pm »
Which monitor are you using?
sphetr2
« Reply #3 on: January 25, 2007, 08:44:35 pm »
I don't know, it came with the machine. Machine is 'Air Buster.'
But what if I don't want to use the original JAMMA controls?
SirPeale
  • Green Mountain Man
« Reply #4 on: January 25, 2007, 09:14:04 pm »
Why not?  What *do* you want to use?
sphetr2
« Reply #5 on: January 26, 2007, 05:02:28 am »
I want to use a ball top joystick and different buttons. Also, I want more buttons per player.
CheffoJeffo
« Reply #6 on: January 26, 2007, 07:42:13 am »
I think you are misunderstanding ... by all means, disconnect the JAMMA harness from the existing controls and put new controls in. Then connect the ends of the JAMMA harness to the new controls.
EDIT: When disconnecting the wires, I recommend labelling where they came from for easy identification and reconnection.
See how you only had to connect some wires for those controls that are JAMMA standard ?
What about extra buttons, you ask ?
Well, now you run the extra wires from the extra buttons to the extra spots on the JPac. But you are only wiring a few buttons per player (since the sticks, coins,P1,P2 and first three player buttons are already wired in the harness), so is a big timesaver.
Oh, almost forgot ... you didn't have to do any wiring at all for that arcade monitor. That's nice, particularly if you are not so sure of your cable-hacking or open-frame monitor abilities.
Did I mention that you are now done and ready to go ?
I don't think I know anyody who keeps the original controls when MAME(tm)ing a JAMMA cabinet ... I sure don't. In fact I will rewire a stripped cabinet JAMMA and drop in a J-Pac because I prefer it to wiring an I-Pac2.
Cheers
« Last Edit: January 26, 2007, 07:47:38 am by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
sphetr2
« Reply #7 on: January 26, 2007, 03:23:59 pm »
Thanks so much for your help. I will be ordering this weekend!
Heh....you hit the nail on the head  ;D
