Author Topic: Just got a 27" bezel, have a question  (Read 1459 times)
needlesmcgirk
  • Last login:September 15, 2009, 10:54:31 pm
« on: January 22, 2007, 01:27:38 pm »
So I just picked up this thing, its a Happs 27" bezel for standard (curved) monitors.  I will be using a 27 inch curved tv as the monitor.  Is this thing going to fit ok or am I going to need to take the casing off the tv?  And how you you guys typically keep these things in place?  thanks so much for your help.
acevedor2
  • Last login:May 25, 2024, 08:21:24 pm
Re: Just got a 27" bezel, have a question
« Reply #1 on: January 22, 2007, 05:25:53 pm »
Completely depends on the TV.  That said, it should fit with the case on.  As far as retaining them, most people use screws and/or wood strips, since you usually put plexi or glas on top of it.
Dedicated - Working:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Pool Sharks - Pinball
Projects:
Pole Position
Pole Position 2
bvicarious
  • Last login:April 15, 2024, 09:43:14 am
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
« Reply #3 on: January 23, 2007, 07:30:08 am »
I have a flat screen monitor and was able to resolve the problem by using a router. I secured my bezel to a flat working surface facing up.  I then used a router with a slot cutter and carefully cut the curved surface away, which left me a flat surface to mount against my flat screen monitor.  I lightly sanded the newly cut area until is was smooth.
If your T.V. has a slight curve that does not match your bezel, you will have to create a template of the curve and transfer it to your bezel for trimming.
John
Galaga... Was there any other game?
