Author Topic: Type of switch? - on top back of ms pacman cabinet.  (Read 1996 times)
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« on: January 19, 2007, 12:46:07 pm »
I have converted a ms pacman cabinet into a mame cabinet.  I notice there's a switch up on the top.  Looks like some kind of metal push button with 3 wire sticking out of it.  Anyone know what type of switch?
Want to know if I can use that as either a push button for power on to pc or a toggle switch for disabling some of the mgmt buttons.
Thanks,
Ken Layton
  • Guru
  • Technician
Re: Type of switch? - on top back of ms pacman cabinet.
« Reply #1 on: January 19, 2007, 01:51:16 pm »
That is the cabinet power on-off switch. It's a single pole single throw (S.P.S.T.) push button switch. The green wire (or green with yellow stripe) is the frame ground wire connected to the metal bracket itself.
xmenxmen
« Reply #2 on: January 19, 2007, 05:08:12 pm »
Thanks, that's what I was guess.  I'll try and write it up and see if it works as a toggle switch, that's assuming the switch is still working.
QuixoteQuest
  • Last login:October 18, 2010, 07:24:11 pm
« Reply #3 on: January 19, 2007, 07:17:08 pm »
I think that is a momentary on switch, yes? If so, it would work fine to turn your PC on, but not good for disabling CP admin buttons, which would need an always on/off switch. (See my thread for my questions regarding switching my coin-up buttons on and off.)
SirPeale
  • Green Mountain Man
« Reply #4 on: January 19, 2007, 07:31:10 pm »
No.
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #5 on: January 19, 2007, 08:07:30 pm »
I plan on using a momentary toggle switch to toggle power on the mobo, and mounting it on the cab in a realistic place (depending on the cab).
For reference, in case someone isn't aware - sometimes the toggle switch specs don't specify momentary, but is often labeled as:
OFF - (ON)
When 'ON' is in parenthesis, it is momentary.
thus "OFF - ON" is a normal switch that will switch and stay in either position.
Hope this helps,
If I do not respond to your post in a timely manner, feel free to PM me.
