Author Topic: Using Gameshouse games in a cab?  (Read 1884 times)
Razor
  • Last login:October 03, 2008, 12:59:59 pm
  • Welcome to the fantasy zone
« on: January 18, 2007, 11:04:43 am »
I have a selection of Gameshouse games I wanted to use in my bartop (http://www.gameshouse.com/), they are controlled by the mouse and I was wondering if it was possible to get these to run through Mala, although I suspect not as theyre not run by an emulator.  Has anyone tried anything similar?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Using Gameshouse games in a cab?
« Reply #1 on: January 18, 2007, 12:13:14 pm »
There ARE front-ends that can launch any EXE file you specify. I don't know which ones.
The next thing you might consider is a touch-screen for input, though trackball might do too.
NO MORE!!
Kaytrim
  • I'm too nice a guy
« Reply #2 on: January 18, 2007, 12:26:34 pm »
GameEx allows you specify program files than can be run in addition to emulators.
Havok
  • Trade Count: (+17)
« Reply #3 on: January 18, 2007, 01:42:20 pm »
All of the major ones can...
All the major FE's can launch executables...
Razor
« Reply #4 on: January 18, 2007, 02:04:56 pm »
Can Mala?  I did have a look in the options but couldnt seem to find anything related.
Havok
« Reply #5 on: January 18, 2007, 02:30:29 pm »
Yes, but that is a question for the Mala users - Loadman will probably see this thread sooner or later...
(I use another front end...   ::) )
Razor
« Reply #6 on: January 18, 2007, 05:25:05 pm »
Thanks for the replys, in hindsight I think im just going to keep it simple as this is my first cab, ive got mame and mala running sweet with my controls and thats good enough for me at this stage :)
jimjim
  • Last login:July 26, 2012, 09:55:53 pm
  • Life is what you make of it.
« Reply #7 on: January 18, 2007, 09:23:34 pm »
I have played many of the gamehouse games on my cab while using Mala as my front end, and I did not find it too difficult to set up.  (Actually it wasn't too difficult after Circo came by to help me :cheers:)  I used the same set-up method to install and launch Wincab on my cabinet.
As far as actually playing the gamehouse games, many of the games require a trackball to play, but are still great for cabs.  The only problem is some of the games are not re-mappable, and would play better with a joystick.  Platypus is a classic example that has been pointed out before.  (I realize that there are some programs to work around this, but I haven't tried them yet.)
I actually got turned onto Feeding Frenzy when I played the Ultracade arcade version of it at a local arcade.  The great thing about many of these games, you get the classic arcade "feel", with up-to-date graphics.  The Ricochet series is a great example of this.
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
« Reply #8 on: January 19, 2007, 02:17:38 am »
Here are some screenshots with how to set up mala for pc games.  The easiest thing is to make a directory and place .lnk files (windows shortcuts) from the actual executables of the games.  Those are your "rom" files so to speak.
My Websites
