Author Topic: Since arcade monitors is so close to SCART's? Can we use this??  (Read 2478 times)
Lilwolf
  • Last login:Yesterday at 09:58:06 am
« on: January 17, 2007, 08:48:54 am »
http://www.svideo.com/svideoscart.html
This converts a SVid -> a SCART output.  Could we use this with a SCART->arcade CRT conversion?
for 18 bucks, this might be a good solution for some people
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
Re: Since arcade monitors is so close to SCART's? Can we use this??
« Reply #1 on: January 17, 2007, 09:03:56 am »
it wont work as all its doing is combining the two parts of the svideo signal (chroma and luma) to form composite video.
arcade monitors are looking for seperate Red, Green, Blue and Sync signals.
Level42
« Reply #2 on: January 17, 2007, 03:21:49 pm »
SCART is a definition of a connector, not of a signal.
SCART can carry:
1) RGB signals - Best quality you can get. DVD players, VGA cards, and arcade PCB's produce RGB signals. All colour signals are seperate AND the sync signal is seperate. Just like the guns in your TV/monitor wants them. The "only" thing the monitor has to do is get the color signals on the right level, and let the electronbeam be controlled by the sync.
2) S-Video
Lower quality than RGB and lower than component out. Carries all color info in one signal. The sync is the second signal. Because these are seperated, it's still beter than composite. However, the monitor has to seperate the three colors that are combined to be able to "feed" them to the elctron guns.
3) composite
All info on one signal, all colors AND the sync are mixed. Monitor/TV has to seperate the syncing from the colors and then the colors from eachother. It's the worst of the three. (Old) VCR's carry this signal, because this is the type of signal recorded on the tape. S-Video came later with S-VHS.
The SCART can actualy do much more than that, but this is the basics. There's plenty of info about SCART on the net....
but.....what actualy do you want to accomplish ?
StephenH
« Reply #3 on: January 18, 2007, 03:33:34 am »
Yes, you can use SCART.  However, for an arcade real picture, don't use an S-Video to SCART converter.  If you use an ArcadeVGA card (15Khz) signal, and connect it via Scart RGB, you actually turn your TV into an arcade monitor!
Jess--
    • My Botched Cab
« Reply #4 on: January 18, 2007, 06:53:51 am »
While you can use the RGB inputs on a scart socket to hook it up as an arcade monitor the adaptor Lilwolf asked about will not work as it is only a svideo to composite adaptor.
