Author Topic: HTML help - how do I make a page that shows more info when a question is clicked  (Read 1396 times)
quarterback
I can't find an example right now, but like a FAQ page that lists a bunch of questions but when you click on a question, the answer appears below it.
Not a page where you 'jump' down the page to the answer, but where the answer just appears, rippling the other questions lower on the page.
So you start off seeing something like this
-Q1- What is MAME?
-Q2- Where can I download the most recent version?
-Q3- Are ROMs legal?
-Q4- How many games does MAME support?
But when you click question #2, you see something like this:
-Q1- What is MAME?
       A: Many versions of the mame executable can be found at http://www.mame.net/downmain.html
I'm going to see if I can find an example and maybe just borrow their HTML, but my guess is that it's some kind of php script or something.   Anybody knew a way to do this or a possible download?
« Last Edit: January 12, 2007, 03:08:44 am by quarterback »
-- Chad Tower
quarterback
Or, alternately, a FAQ like this one:
http://www.google.com/support/webmasters/
or this one
http://www.myspace.com/index.cfm?fuseaction=misc.faq
Where you click a question, go to a new page but there's a little navigation 'bar' at the top like this:
Skip Navigation LinksHelp with FAQ > Artist/Band Questions > How do I become a featured artist?
« Last Edit: January 12, 2007, 02:55:09 am by quarterback »
-- Chad Tower
JamIt
  • Last login:June 17, 2011, 03:27:07 pm
Here's a snipet I've used in the past.  It probably only works with IE, but I hope it helps get you started.
--JamIt
Code: [Select]
<html>
<head>
<SCRIPT type=text/javascript>
function expandColapse(sH,sD)
var h, d;
var s;
//h = document.getElementById('headerrow' + sH);
for(i=1; i <= sD; i++)
try
  d = document.getElementById('datarow' + sH + '.' + i);
  if (d.style.display == 'none')
    //h.src = 'test_files/minus.gif';
    d.style.display = 'block';
  else
    //h.src = 'test_files/plus.gif';
    d.style.display = 'none';
catch(e)
</SCRIPT>
</head>
<body>
<table>
<tr><td valign="bottom"><span title="spn1"><a href="javascript:expandColapse(1, 1);">Q1</a></span></td></tr>
<tr id="datarow1.1" style="display:none"><td width="1"></td><td valign="top" nowrap colspan="1">A1</a></td></tr>
<tr><td valign="bottom"><span title="spn2"><a href="javascript:expandColapse(2, 1);">Q2</a></span></td></tr>
<tr id="datarow2.1" style="display:none"><td width="1"></td><td valign="top" nowrap colspan="1">A2</a></td></tr>
</table>
</body>
</html>
quarterback
Thanks a bunch JamIt.  It got me thinking the the right direction (which is javascript, which wasn't where I was thinking :))  Looks like I'll be good to go.
Thanks again.
-- Chad Tower
