Author Topic: Yet another AtomicFE Question...  (Read 1556 times)
Catastrophic
  • Last login:January 02, 2012, 10:25:03 am
« on: January 10, 2007, 01:17:16 pm »
How do you keep AtomicFE from quitting to windows with the ESC key?
The cab I'm setting up is for some kids and it needs to be as bulletproof as possible...
I'm sure there is some simple solution, but I can't seem to find it.
« Last Edit: January 11, 2007, 11:36:10 am by Catastrophic »
Havok
  • Trade Count: (+17)
Re: AtomicFE Question
« Reply #1 on: January 10, 2007, 02:16:50 pm »
There are two ways you could go about doing this:
1. Re-map your keys: Run AtomicKeys.exe to re-define what key escapes to windows
2. Set a password to exit: Run AtomicManager.exe, check-mark Advanced Options, go to the Options Tab, then Option3, check-mark "Ask for password on exiting front end" and click the Define button to set a password. For the most part, you can only use the alphabet keys; however you can also use Escape, Backspace and Space in the sequence.
Note: A keyboard is not required for this; you would simply press the buttons corresponding to your password. (Example:  Right, Right, Up, Up, Down, Down)
Since kids are involved, I would recommend the password option!
Catastrophic
« Reply #2 on: January 10, 2007, 02:55:21 pm »
Awesome, Havoc!  Thanks alot!
U D Man!
Exclamation point!
Catastrophic
Re: Yet another AtomicFE Question...
« Reply #3 on: January 11, 2007, 11:38:11 am »
Continuing my string of helpful AtomicFE questions...
Is there a way to skip the PulgnPlay module selector screen?  That is, can I have Atomic start up and load the Simple Arcade module automatically without the kids having to select it?
Thanks for the reply!
MYX
    • MYX Digital Blog
« Reply #4 on: January 11, 2007, 01:42:59 pm »
I recently asked the same thing. It is part of the process. I know you can set it up to go directly into a game (random game or specific) But even when you set this up (Atomic manager - arcades config) I believe you still have to go through the PNP page. Try it.
M    Y    X
Havok
« Reply #5 on: January 11, 2007, 01:49:34 pm »
Come on, you've got to give me something harder!
To skip the plug and play selector screen:
1. Run PlugnplayManager.exe
  • Select Arcades Simple
  • Click the Disable button
  • Click Exit
2. Run AtomicManager.exe
  • Click the Load Config button
  • Browse to C:\AtomicFE_v018\plugnplay\arcades_simple\arcades.cfg. (assuming you went with a default install)
  • Click Open
  • Click the Setup as Start Config
  • Click OK
  • Click the Save button, then Save. Click OK to confirm
  • Click Close, then OK
That should do it! The next time you run Atomic, it should default to the ArcadeSimple layout, without having to select it first.
If you ever change your mind, and want to add additional emulators, then to switch back is simple: just open the plug and play manager program, and enable the arcades simple module.
Havok
« Reply #6 on: January 11, 2007, 01:51:16 pm »
Sorry MYX - I must have missed your original post! To be honest, I just figured this out - I never tried it before...
(One of the perks of being an IT guy for a living!)
Catastrophic
« Reply #7 on: January 11, 2007, 02:09:31 pm »
Your solution worked like a charm Havok!  However, it nuked my game list and I got the dreaded "No Roms Found" when it restarted.  After looking around, I discovered that in AtomicManager.exe under Advanced>Game List, the "Use Predefined Game List" box was checked.  I unticked that and restarted, AtomicFE recompiled the list, and all the Roms are back in their arcadey glory.
Since you are AtomicFE's documentation guy, I would suggest including the answers to both my questions in your next iteration.  I bet there are quite a few people looking at Atomic as the front end for kids' cabs because of it's ease of use and pretty picture layouts.  But they will certainly need to eliminate the ESC button possibility and might want to launch straight into the arcade module (or any other module) just like I did.
Thanks for all your help, I think this build is just about complete! :cheers:
Havok
« Reply #8 on: January 11, 2007, 02:17:15 pm »
Glad to see all is working. Great idea about including your questions - I'll throw them in the Troubleshooting section on the next update, which is coming soon...
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #9 on: January 12, 2007, 03:21:51 am »
Hum..that's strange, the method havok described should work without having to untick something.
Did you modifify the Arcade Simple.cfg  except that  before doing the trick?
I will check that.
