Author Topic: Info on CM A14 needed  (Read 2764 times)
johnnya
  • Trade Count: (+26)
  • Last login:January 08, 2023, 10:37:08 pm
  • Who's gonna turn down a Junior Mint?
« on: January 08, 2007, 10:12:48 pm »
I have a generic cocktail cab with a CM A14 chassis in it, which I believe is a Toei.  It does look very similar to the CM A20 found on Bob Robert's chassis ID page here http://www.homearcade.org/BBBB/mon64.jpg.
Does anyone have any info on this chassis?
johnnya
Re: Info on CM A14 needed
« Reply #1 on: January 10, 2007, 09:56:11 pm »
The reason I ask is that it used to come on and be playable for a while before the monitor would blank out.  Over time, the time it would be playable would get less and less.  Now, it will go out very quickly, and when you reset it, it comes on for only a couple seconds, not even enough time to get an image onto the monitor, and then it cuts off.
Any ideas?  I tried another game board in it, and it does the same thing.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: January 11, 2007, 12:05:19 am »
Toei's are not common and are very hard to find parts for in the USA.
graphicfx2k5
  • Last login:April 20, 2017, 09:41:43 am
Re: Info on TOEI CM R14 needed
« Reply #3 on: May 17, 2009, 07:15:38 pm »
Looking for information on a Toei CM-R14 the tube actually works but i'm finding it hard to set the V-hold-and H-hold It worked for last week...and now it's crazy hahaha  I'm trying to keep the faith with the older monitors.....trying to resist the pull to a VGA connection.
If anyone has any pdf's on the Toei model that would be awesome ;-)
Dwight
graphicfx2k5
« Reply #4 on: May 17, 2009, 07:19:11 pm »
Hey did you find any information on your Toei?  I have a CM-R14 that is also a Toei that i'm trying to find info on...they are buggers to fix up.
I'm Dwight from Hamilton, Canada
Cheers'
Dwight
