Author Topic: seeburg c or b cabinet measurements needed  (Read 4502 times)
mr_cbf
  • Last login:March 12, 2007, 07:33:08 am
« on: January 03, 2007, 04:18:53 am »
Hi Guys
Hopefully someone out there knows of someone who who has a seeburg c or b jukebox. I'm after dimensions so I can build one to create my own jukebox with a touchscreen where the title strips go.
I have pictures of them and know the rough height, width but was after more pictures or exact measures which will make building it easier. If anyone can help out with measurements of all angles it would be appreicated.
Big project I know, but wont be the same thing obviously as not that good, but hoping to mirror there design a little. Thanks again
Karaokedude
  • Last login:October 16, 2007, 12:21:00 pm
Re: seeburg c or b cabinet measurements needed
« Reply #1 on: January 08, 2007, 03:15:00 pm »
The B and C you mean the 1936 Symphonola
B   H 51 W 30 1/4 D 21 3/4
C  H 55 W 31 3/4 D 21 3/4
hope this helps
mr_cbf
« Reply #2 on: January 11, 2007, 11:50:45 pm »
HI mate
Thanks for the above, but actually after the M100 series in the 1950's. Believe 1953 it was made..
If anyone can help out with some details measurements it would be great.
Thanks Mal
Karaokedude
« Reply #3 on: January 12, 2007, 08:57:01 pm »
M100A 1948-51      55H  41W 29D
M100B  1950-51    54H      34W     28D
M100C   1952     54H    35W     26D
all in inches
Karaokedude
« Reply #4 on: January 12, 2007, 09:01:45 pm »
 nearly all the  post 1950 pre 1960 SeeBurgs are about the same size
theres only an inche difference in most of the dimensions an average  over 40 models is 55H 35W 27D
mr_cbf
« Reply #5 on: January 13, 2007, 04:23:28 am »
Excellent, thanks for that mate.... If anyone have one at home and they can do exact measures of side parts and so on would be appreciated. But thanks mate, this will give me the start anyways to what I needed. Cheers
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
« Reply #6 on: January 15, 2007, 02:56:51 am »
Why such an obsession with exact measurements? If you build something and find out later that it's off by an inch in some direction or another, are you going to be devastated?
mr_cbf
« Reply #7 on: January 15, 2007, 05:14:28 am »
By exact, I'm looking at each part of the actual outside section so I know how round it is etc... If it's out, not at all worried but the more measurements I get the easier it's going to be to cut the wood out, wouldn't you agree?
It's like anything the more info you have the better an end result or hopefully easier the project becomes. Thanks again to those that helped out, appreciated.
mr_cbf
« Reply #8 on: February 01, 2007, 03:23:05 pm »
Hi All,
I got all the measurements I need. have posted a picture below if anyone wants it also.
Cheers
fredster
  • It's all good!
« Reply #9 on: February 01, 2007, 05:09:18 pm »
How are you going to handle the curved glass portion?
mr_cbf
« Reply #10 on: February 02, 2007, 08:12:38 am »
Hi Fredster,
Going to go to a local place here in Melbourne to chekc out perspex being bent into that shape. Should be able without any hassle get them to bend standard clear plastic into that shape. I know the high of the glass but will do my own version to fit the frame I build, but will be similar to what is pictured. sorry spoelling is crap, little bit driunk :)
Cheers Mal
