Author Topic: Vertical games on Arcadevga interlaced.  (Read 1468 times)
vocalninja
  • Last login:January 30, 2015, 01:50:53 am
« on: December 20, 2006, 06:38:32 pm »
I've been playing around with dodonpachi on a rgb monitor. the game starts in vertical orientation (which is what i want) but its an interlaced image. Is there a way to get games like these to display vertically AND have progressive scan at their correct resolution on an arcade monitor.
I'm using mame32 and an arcadevga. Any help regarding mame and vertical shooters would be much appreciated.
I've spent a fair amount of time in the mame32 ini file but no luck.
TalkingOctopus
    • My Arcade
Re: Vertical games on Arcadevga interlaced.
« Reply #1 on: December 20, 2006, 10:25:02 pm »
Yes.  I have a vertical astro city cab and I used Minwah's MAME resolution tool along with arcadeVGA.  Get it here:
http://mamewah.mameworld.net/downloads.htm
This generates the correct INIs for each game, although you may have to remove some resolutions that aren't supported by your monitor.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #2 on: December 21, 2006, 03:51:53 am »
You can use AVRES tool from Ultimarc too.
You can find a version on ultimarc's web site.  Or take that one :
http://www.atomicfe.com/Downloads/avres.zip
