Author Topic: Anyone use Happs Vinyl to finish a cabinet?  (Read 2670 times)
MannyTC
  • Last login:May 12, 2003, 01:33:28 am
  • Jack Burton... Me!
« on: March 30, 2003, 04:53:32 pm »
Wondering if anyone here has used Happs vinyl for convering a cab. Any comments? Any pics? I was considering this instead of laminate.
steve_pss
  • Last login:December 19, 2020, 06:56:53 pm
Re: Anyone use Happs Vinyl to finish a cabinet?
« Reply #1 on: May 22, 2005, 07:42:24 pm »
Great stuff. Make sure you pay careful attention to closely trimming the edges or when you fit in your t-moulding it will bubble up.
Goz
  • KOTA
« Reply #2 on: May 22, 2005, 09:01:19 pm »
It works great! Make sure you have plenty of sharp razor blades / xacto knife blades for trimming. I'll see if I can get a decent picture of the cab i did it to. (My gameroom is dark w/ Neon and special lighting pics don't often come out well).
It's only practical when they put it on sale. I for instance got in when they had the HAPPS Pica 'D' Vinyl on sale for $2.50 it's usually at about $5
-Goz
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
« Reply #3 on: May 22, 2005, 09:12:36 pm »
Does anyone know the thickness of this stuff?
I don't see it on the site:
http://www.happcontrols.com/vending/acesor/49057200.htm
Elfman
  • Last login:February 01, 2012, 05:58:11 pm
  • Cabinet done! CP Done! Just tweaks left to do.
    • My Corner of the World
« Reply #4 on: May 23, 2005, 10:06:03 am »
Never used the Happ stuff, but did use the Parts Express stuff.
dema
  • Last login:September 02, 2014, 03:05:34 am
« Reply #5 on: May 23, 2005, 10:45:19 am »
Yeah, a close-up picture would be very much appreciated. I'm debating whether to go the vinyl or the laminate route.
IntruderAlert
    • Intruder Alert
« Reply #6 on: May 23, 2005, 11:13:58 am »
so how thick is that stuff?
If you're able to bend it around the edges of the cab and tuck it under the t-molding it can't be very thick i guess
Plus, since this stuff is textured will you still be able to apply side art?
dema
« Reply #7 on: May 25, 2005, 08:38:01 am »
Anybody have any information or better pictures of this vinyl?
Dexter
  • Patriotism, the last refuge of the scoundrel. -- Irish, darnit!
  • Last login:February 01, 2024, 04:36:19 pm
  • "MAKE POVERTY HISTORY......."
« Reply #8 on: May 25, 2005, 09:44:34 am »
Not a great pic but better than nothing
Happ black pica vinyl covering small control panel on a cocktail cab i built...
dema
« Reply #9 on: May 25, 2005, 09:51:43 am »
It looks good. Is it very thick?
Knievel
    • Knievel Kustoms
« Reply #10 on: May 25, 2005, 11:24:10 am »
The Happ stuff is thicker/heavier/tougher. I couldn't get it to fold over an edge without some degree of bubbling so you'd have to cut it flush. That being said it's great for front panels, CP tops/boxes.
It is a very fine texture, no problems with sideart.
It's way too expensive normally. Ponyboy might be able to get you a decent price if it's not on sale at Happ.
dema
« Reply #11 on: May 25, 2005, 02:12:45 pm »
That's a bummer. I was hoping to run it from the base all the way up the front, and fold it over the front edge of my Rebirth-style rotating control panel. The problem is that would require a bend of 135 degrees. I'm hesitant to try cutting it flush because I'm sure the vinyl would pop up at the edge over time, especially as the control panel was rotated and got some heavy use.
dema
« Reply #12 on: May 25, 2005, 02:23:02 pm »
Knievel, did you use this stuff on the Xmen cab you did?
« Last Edit: May 25, 2005, 02:57:09 pm by dema »
sdrob04
  • Last login:February 18, 2021, 02:12:50 pm
« Reply #13 on: May 25, 2005, 03:57:38 pm »
Finally--an opportunity to offer some advice as opposed to always asking for it!
« Last Edit: May 25, 2005, 04:05:10 pm by sdrob04 »
AlanS17
    • AlanS17
« Reply #14 on: May 25, 2005, 04:26:00 pm »
Well done, sdrob04. How long ago did you do that? Is it holding up well? The same thought occurred to me, but I haven't been able to test the theory out. I'm glad to here it's a sound theory.
Knievel
    • Knievel Kustoms
« Reply #15 on: May 25, 2005, 04:37:53 pm »
No, just paint...and that's not the X-Men cab :)
sdrob that's a great idea using the iron. I used to be a model plane builder and I've got one of those sitting here, just never thought of it. I'd be interested to know how it holds up in the future. It's beautiful stuff but I'm still worried about it lifting on the edges...gonna have to try it for myself I guess.
Did you have a Happ-Sock on that iron? ;D
sdrob04
« Reply #16 on: May 25, 2005, 05:34:31 pm »
Both the lamination and t-molding work was just finished this past weekend, so I don't have any long-term results just yet.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #17 on: May 25, 2005, 05:42:22 pm »
its good stuff but need to be precise when you apply it as doesnt move once its applied.
rchadd
  • Made in Cornwall
« Reply #18 on: May 25, 2005, 05:44:34 pm »
thats exactly i used mine for - i am really happy with it
