Author Topic: MAME ignoring my INIs?  (Read 1607 times)
FrizzleFried
    • Idaho Garagecade
« on: December 16, 2006, 10:55:39 am »
MAME is ignoring my INIs.   Hell,  when I go in to the MAME RES TOOL,  then change a resolution for a game...it doesn't actually change it?!
For example...Mr. Do is rolling on me.  So I go in to the MAME RES TOOL to change the resolution to one that doesn't roll and no matter what I select (even 640x480),  the resolution doesn't change,  it still keeps the same res as before,  and it still rolls.
Anyone know if there is some sort of setting in the MAME.INI I messed up or something?   The other answer is to start from scratch,  delete all the INI files,  delete the res tool,  MAME,  and re-install...which I'd like to avoid.
jcrouse
    • CPViewer
Re: MAME ignoring my INIs?
« Reply #1 on: December 16, 2006, 03:27:13 pm »
Well, that is tought to answer without seeing the file. :) Taking a wild guess, did you set the ini path properly in the file?
Good Luck,
John
FrizzleFried
    • Idaho Garagecade
« Reply #2 on: December 16, 2006, 04:22:00 pm »
Sorry....
# CONFIGURATION OPTIONS
readconfig                1
skip_gameinfo             0
# PATH AND DIRECTORY OPTIONS
rompath                   roms
samplepath                samples
inipath                   .;ini
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
artpath                   artwork
snapshot_directory        snap
diff_directory            diff
ctrlrpath                 ctrlr
comment_directory         comments
cheat_file                cheat.dat
# MISC OPTIONS
bios                      default
cheat                     0
# STATE/PLAYBACK OPTIONS
# state                   <NULL> (not set)
autosave                  1
# playback                <NULL> (not set)
# record                  <NULL> (not set)
# mngwrite                <NULL> (not set)
# wavwrite                <NULL> (not set)
# DEBUGGING OPTIONS
log                       0
oslog                     0
verbose                   0
# PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
frames_to_run             0
throttle                  1
sleep                     1
rdtsc                     0
priority                  0
multithreading            0
# VIDEO OPTIONS
video                     ddraw
numscreens                1
window                    0
maximize                  1
keepaspect                1
prescale                  1
effect                    none
pause_brightness          0.65
waitvsync                 0
syncrefresh               0
# VIDEO ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D-SPECIFIC OPTIONS
d3dversion                9
filter                    1
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 1
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# GAME SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
# VECTOR RENDERING OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# ARTWORK OPTIONS
artwork_crop              0
use_backdrops             1
use_overlays              1
use_bezels                1
# SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
audio_latency             1
# INPUT DEVICE OPTIONS
# ctrlr                   <NULL> (not set)
mouse                     1
joystick                  0
lightgun                  0
dual_lightgun             0
offscreen_reload          0
steadykey                 0
a2d_deadzone              0.3
digital                   none
# AUTOMATIC DEVICE SELECTION OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
« Last Edit: December 16, 2006, 04:32:43 pm by FrizzleFried »
FrizzleFried
    • Idaho Garagecade
« Reply #3 on: December 16, 2006, 04:34:08 pm »
Running an ArcadeVGA card / JPAC to Arcade Monitor BTW.
jcrouse
    • CPViewer
« Reply #4 on: December 16, 2006, 05:12:50 pm »
Try removing the .; from the ini path line near the top.
John
