Author Topic: 8liner 25 inch Chassis  (Read 2038 times)
mckay24
  • Last login:December 02, 2007, 02:26:29 pm
« on: December 14, 2006, 09:03:08 am »
Hi, wonderful board,...........learned plenty from you guys.
I bought 3 329-25 chassis from atlas and 2 of them worked great!,........but one is not,.........i hear a flyback whine,.......and there is 165 volts on b+,........... but it fails to charge up the tube nor do I see a glow in the neck of tube,.......... no the tubes prob, because i was able to get it working with the other chassis.
I live in Canada,......would prefer any help on trying to fix it first before sending back as they were quick to suggest for me,......... any suggestions?
Thanks Jim
mckay24
Re: 8liner 25 inch Chassis
« Reply #1 on: December 14, 2006, 10:01:07 pm »
lol I gather by lack of any responses, i should just send it back :)
Ken Layton
  • Guru
  • Technician
« Reply #2 on: December 14, 2006, 11:46:01 pm »
Since it's brand new and under warranty, I'd send it back for repair or exchange.
mckay24
« Reply #3 on: December 15, 2006, 09:06:10 am »
OK,...thanx
From where I am the cost of shipping almost is more than the value of this chassis and return shipping.
Was just trying to avoid that,..........but maybe if I were to purchase more, it might make it more reasonable.
« Reply #4 on: December 15, 2006, 09:53:51 am »
Check to make sure you didn't bend a pin on the neck when you were putting the neckboard on.  I've done that more times than I want to admit and thought a chassis was bad.
mckay24
« Reply #5 on: December 15, 2006, 10:04:05 am »
Hi,
Yeah I did try it on three different tubes,...........plus the tubes I did try it on,........the other two chassis worked fine on them.
I must have spent hours checking continuity on the traces from the flyback,....... and checking solders,............just bad luck I guess,.....bad component somewhere I believe.
Thank You
