Author Topic: G07 Tube Question  (Read 2057 times)
FrizzleFried
    • Idaho Garagecade
G07 Tube Question
« on: December 14, 2006, 01:10:34 am »
OK...I have a 19" Rauland 19VMBP22 tube that has zero burn in.   It currently is powered by a PowerMax 1000C chassis which is a re-branded Wei-Ya that is having some geometry issues that a cap kit didn't fix.
I came across a G07 CB0 working monitor with moderate burn-in for $40.  I would like to swap out the chassis from the damaged tube to the good tube.   Since the good tube was using a chassis that is a "G07 Replacement" it stands to reason that I should be able to do a direct swap without changing the yoke/etc...right?
The good monitor has an ID of 19VBMP22 and the burned monitor has an ID of 19VMJP22.
« Last Edit: December 14, 2006, 02:03:49 am by FrizzleFried »
Ken Layton
  • Guru
  • Technician
Re: G07 Tube Question
« Reply #1 on: December 14, 2006, 02:45:30 am »
The Electrohome yoke connector wiring is different than the connector wiring on the Wei-ya chassis so watch wire color & function lest you damage the chassis.
http://arcarc.xmission.com/PDF%20Monitors/Eygo%20chassis%20Replacement%20for%20G07.pdf
That link will show you the wiring changes on the yoke connector.
« Last Edit: December 14, 2006, 02:55:38 am by Ken Layton »
shess
  • Last login:January 07, 2021, 04:17:28 pm
« Reply #2 on: December 14, 2006, 06:45:09 am »
If you swap the yokes as well does that eliminate the problem with mismatched hardware?
FrizzleFried
    • Idaho Garagecade
« Reply #3 on: December 14, 2006, 09:36:24 am »
My Wei-Ya has a converter that goes from the stock G07 yoke connection to the Wei-Ya connection....if I remove this and plug the old connector in in the correct way,  all should be good....
....at least thats what I hope.
