Author Topic: Is 7-volts too much for a 5-volt requirement?  (Read 2406 times)
postalp123
  • Last login:March 18, 2024, 09:07:50 pm
  • Retro-gamers don't just play, they reminisce.
« on: December 12, 2006, 10:55:57 am »
As posted before, I was looking for a power source for my druin board (requires 5-volts).
I managed to find an old AC adapter running 7-volts AC, is this too much for the Druin to handle?
-PP
Re: Is 7-volts too much for a 5-volt requirement?
« Reply #1 on: December 12, 2006, 10:58:15 am »
Depends on the application, really.  No way to answer that without knowing what it's being fed into.  Lots of 5v things get 7-8v in and regulate it down inside.  Lots don't.
postalp123
« Reply #2 on: December 12, 2006, 11:02:29 am »
For the record heres what I'm powering:
http://ca.geocities.com/druins22@rogers.com/ls30/
Ed_McCarron
« Reply #3 on: December 12, 2006, 11:04:47 am »
Not really familiar with that board, but looking at it I'll make two assumptions:
That theres no regulator, unless theres one built into the chip.  Not likely.
It wants DC, not AC.  That reg won't work regardless of voltage.  Looks like DC in is on the top barrier terminal, and ties right to +5v and gnd.  The electrolytic cap is for filtering.  No regulation/rectification.
Ed_McCarron
« Reply #4 on: December 12, 2006, 11:06:46 am »
Looked at the schematic.
5v DC only.
Can you pull it from a drive connector on the computer you have in there?  I assume this is a MAME app?
« Reply #5 on: December 12, 2006, 11:11:54 am »
If I recognize that chip properly, it's just an eeprom.  No voltage changing whatsoever.
Havok
  • Trade Count: (+17)
« Reply #6 on: December 12, 2006, 12:05:09 pm »
Why can't you pull 5v from the computer power supply? I would think that is the best solution. Both the Ipac and Keywiz\GPWiz have a 5v tap for just this thing. Worse case - buy a universal adapter for $10 and wire that up...
Ed_McCarron
« Reply #7 on: December 12, 2006, 12:46:36 pm »
ATMEL is all about microcontrollers now... Judging by the fact that its the only chip there, thats what I'd assume it is.
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #8 on: December 16, 2006, 07:12:11 pm »
Yes, it is a microcontroller.  Feeding it 7V will not work.
If I do not respond to your post in a timely manner, feel free to PM me.
Kevin Mullins
    • Me on Myspace
« Reply #9 on: December 16, 2006, 09:23:58 pm »
Maximum DC voltage listed is 6.0v ......... DC
http://www.atmel.com/dyn/resources/prod_documents/doc1477.pdf
As already mentioned....
Use the 5.0v DC from a PC power supply if this is indeed for a MAME project or something similar that is using a PC.
