Author Topic: Medium res games on Standard Res monitor?  (Read 4999 times)
mamerocks87
  • Last login:March 17, 2007, 12:21:33 pm
« on: December 05, 2006, 11:28:43 pm »
Can you play a game that uses a medium res monitor on a standard res monitor? I know that I have heard that some games can use different res monitors. I have a mame machine with a standard res monitor in it and want to purchase a gauntlet legends pcb/hard drive and hook it up to my machine. According to the international arcade museum its a medium res game  >:( http://www.arcade-museum.com/game_detail.php?letter=G&game_id=7926 Enlighten me...
Ken Layton
  • Guru
  • Technician
Re: Medium res games on Standard Res monitor?
« Reply #1 on: December 06, 2006, 12:30:15 am »
NO No NO. Feeding a medium res signal to a standard res monitor can damage or even destroy the monitor.
mamerocks87
« Reply #2 on: December 06, 2006, 12:11:04 pm »
Do some games have some sort of switch to switch the output to different reses?
SirPeale
  • Green Mountain Man
« Reply #3 on: December 06, 2006, 07:49:48 pm »
Some games (like Blitz) have a dipswitch setting to go from standard to medium res and back.
But the monitor has to support the resolution.
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #4 on: December 06, 2006, 10:27:40 pm »
Check with whoeveryou are about to buy the game from. I am not positive, but I think it can be switched to Standard res.
I have had at leat one customer tell us he has used our standard res 27" (model 1527) in Gauntlet the Legends, I have had others tell me they used our model 3M27 that supports Standard res, Mid res and VGA.
If you run into a dead end finding out for sure, e-mail me directly and I will try to contact the customer to confirm.
Rick Nieman
Nieman Video Displays
Rick@niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
SirPeale
« Reply #5 on: December 08, 2006, 07:10:33 am »
That would make sense; the board (if it's the one I'm thinking of) is the same thing as a Blitz board. It's just a ROM swap.
Q*Bert_OP
  • Oh yes, we did!
« Reply #6 on: December 09, 2006, 07:06:59 pm »
This game sure does...Dipswitch (U12)...Set switch numbers 1 and 2 to the off position for low res mode...
Nope, not the same as a blitz board...blitz is seattle hardware, gauntlet is vegas hardware...but they both can use either low or mid res...
StephenH
« Reply #7 on: December 09, 2006, 09:15:37 pm »
In order to run medium res games on a standard res monitor you would need a scan converter, if the game in question cannot output standard res 15Khz
castlesteve
  • Last login:September 12, 2014, 09:10:32 am
  • uh, yea
« Reply #8 on: December 12, 2006, 09:38:10 am »
I would also like add a question about the same thing.
I have a NFL Blitz game board... if I set the DIPS to 15Khz mode, will it work with a wells k7100 (25k7193)?
It wont damage it by experimentation, will it?
Thanks,
Steve
Q*Bert_OP
  • Oh yes, we did!
« Reply #9 on: December 12, 2006, 05:39:16 pm »
Thanks,
Steve
Yes, your k7100 is compatable...no, you won't damage it...
castlesteve
  • uh, yea
« Reply #10 on: December 12, 2006, 07:30:54 pm »
I am a  :tool:
I should have taken monitors for idiots... because i made the classic mistake... hooking power up to the wrong side of the isolation transformer
Now... after putting the monitor back in the original cabinet... and replacing the fuse on the board... it now blows fuses in the isolation transformer.
So apparently, im shorting something out on the power side.
I cant locate the Wells 25k7197 (7000 series) flowcharts ...
Should I just purchase a new board and be done with it?  Anyone have a good reccomendation on a board vendor for this monitor?
I feel like an idiot... so flame away.  I wont even fight it :)
-Steve
SirPeale
« Reply #11 on: December 12, 2006, 08:28:03 pm »
No!  The K7000 series is a good monitor.
Start where the power goes into the monitor and start testing components.  Start with the bridge diodes, work your way to the HOT, etc etc.
