Author Topic: Problem with Happ Top Firebutton Super Joystick  (Read 1164 times)
lettuce
  • Make It So!
« on: December 03, 2006, 08:33:30 am »
I have a Happ Top Firebutton Super Joystick , and am having a problem with the fire button. As you probably know there is an 'aluminum hook/plate' that sits between the micro switch and the plugger that presses down the 'aluminum hook/plate' to press the micro switch (dont know if ive explained that very well, but you'll know what i mean if you have one of these sticks). The problem im have is this 'aluminum hook/plate' has been bent out of shape slightly and i can seem to get the correct shape back to it. I either bend it so it is pressing the micro switch all the time, or doesnt register when i press the button the top of the stick, or only registers the button press if i have the stick in a certain direction. Has anybody got an tips for me to get the fire button working again??
Edit: just looked on the Happ site and the proper name for the  'Aluminum hook/plate' is, ACTUATOR METAL F/TULIP
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
Re: Problem with Happ Top Firebutton Super Joystick
« Reply #1 on: December 03, 2006, 01:20:10 pm »
you have him to bend. This is easy. angle be bent about 9 degrees. Red it is correct
NoOne=NBA=
« Reply #2 on: December 03, 2006, 02:05:27 pm »
Also, make sure the "T" part at the one end is seated properly in the notch for it.
It's really easy to get that out of the proper notch, which causes it to not pivot properly.
lettuce
  • Make It So!
« Reply #3 on: December 03, 2006, 02:29:47 pm »
Ok, cheers guys, ill give it a go
