Author Topic: DPI  (Read 1851 times)
Razor
  • Last login:October 03, 2008, 12:59:59 pm
  • Welcome to the fantasy zone
DPI
« on: November 29, 2006, 03:49:37 am »
Hi, how do I check the DPI on some .ai images?  The place im getting them printed at wants 300 minimum, help would be appreciated.
MaMeNnO
  • Last login:August 10, 2025, 04:26:53 pm
Re: DPI
« Reply #1 on: November 29, 2006, 07:28:11 am »
Adobe Illustrator is vector based. You should convert it into some bitmap format (.jpg, .png, etc) with 300dpi.
Ad_Enuff
  • Last login:May 23, 2013, 01:52:14 pm
  • Forensic Imager
    • MAME COVERS
To clarify on this point....
« Reply #2 on: November 29, 2006, 01:48:50 pm »
You can print directly in AI to the size you want without conversion to a raster. AI is a mathematical based artwork program and therefore doesnt require you to set any DPI at all.
Just make sure your artboard and artwork is set to the print size you require...thats it.
If you are going to convert an AI file to a raster, ensure that you only save it in 3 formats: BITMAP (BMP), PNG or TIFF as they are uncompressed and will preserve all the quality a vector drawing is capable of providing.
DO NOT USE JPEG!
« Last Edit: November 29, 2006, 01:53:37 pm by Ad_Enuff »
Ad_Enuff
www.mameworld.net/mrdo/mame_artwork.html - (MAME Artwork Project)
Razor
Re: To clarify on this point....
« Reply #3 on: November 29, 2006, 02:18:10 pm »
DO NOT USE JPEG!
Fine these are all sorted now ready to be printed, thanks
« Last Edit: November 29, 2006, 06:06:05 pm by Razor »
