Author Topic: COIN MECH HELP  (Read 3942 times)
smythe
  • Last login:June 13, 2010, 04:28:06 pm
COIN MECH HELP
« on: November 28, 2006, 06:02:06 pm »
ive just picked up a jamma cab
but the coin mech dont work
theres a credit board with coin 1 & ground
theres nothing else
should there be some power to the coin mech?
cheers sjj
Ken Layton
  • Guru
  • Technician
Re: COIN MECH HELP
« Reply #1 on: November 28, 2006, 06:14:31 pm »
Pictures please. And don't forget those of us on dialup that can't wait all day for a picture to load.
fatfingers
  • Got UltraStiks?™
Re: COIN MECH HELP
« Reply #2 on: November 28, 2006, 06:31:30 pm »
And don't forget those of us on dialup ...
Mom?  Is that you?   ;D
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
grantspain
Re: COIN MECH HELP
« Reply #3 on: November 29, 2006, 03:32:01 am »
depending on the credit board you will need +12volts and common,at the moment it sounds like you have coin signal and coin common only,i guess you are using a electronic coin mech like a c120 or sr3
if you look at your credit board it should have written next to the input plugs what you need e.g +12(+v, com(grnd),coin,lamp,coin counter(meter)
what credit board is it?
smythe
Re: COIN MECH HELP
« Reply #4 on: November 29, 2006, 04:43:16 pm »
coin mech is me126
credit board is philip shefras
the above are connected together with a ribbon connector
ill try and get a picture ...
when u say 12+ ect where do i get this power from?
cheers
grantspain
Re: COIN MECH HELP
« Reply #5 on: November 29, 2006, 06:38:43 pm »
power supply or the jamma connector,i am very familiar with both the mars mech and the pre deith leisure credit board
smythe
Re: COIN MECH HELP
« Reply #6 on: December 04, 2006, 09:43:09 am »
heres the connetors for credit board
con2 - 100/50/20/10 (no wires in these)
con3 - com/no/mtr/lamp (meter wire in mtr)
con 5 - 21/21/21/no (other meter wire in 1st 21)
a quick connect different to above  - coin 1 & gnd connected to this
there are also 2 set of dips
any idea where i put +12v & com
cheers
p.s. i have one of those hanterex newer type power supply
grantspain
Re: COIN MECH HELP
« Reply #7 on: December 04, 2006, 10:00:08 am »
how many pins on the quick connect?and what is the colour of the board?
« Last Edit: December 04, 2006, 10:03:05 am by grantspain »
smythe
Re: COIN MECH HELP
« Reply #8 on: December 04, 2006, 10:45:13 am »
hi the quick connect is a plug type connector when the plugs removed
theres one pin then one missing then four together so 5 pins but a 6 pin plug..
at 1st glance the board looks green but when theres a bit of light behind it it looks blue....
cheers in advance
grantspain
Re: COIN MECH HELP
« Reply #9 on: December 04, 2006, 11:03:09 am »
how good are you with a multimeter?
do the quickfit connector pins have anything written on the board,use a flashlight
smythe
Re: COIN MECH HELP
« Reply #10 on: December 04, 2006, 11:39:28 am »
nothing written on the board only jfmamjjasond think thats just the months of the year..
ive turn the plug round and now the credit button on the board works (some gimp put the plug on back to front)
does this mean the board now has some kind of power?
p.s. the coin mech dont work still (has a sticker saying new 50p) thats what ive been trying
cheers
grantspain
Re: COIN MECH HELP
« Reply #11 on: December 04, 2006, 12:47:00 pm »
for you to get credit from the credit button on the credit board  must mean you have power,clean the coin mech and test with a 20p coin
you can meter voltages on the coin mech ribbon cable to see if you have power to the coin mech if you have a multimeter,you could have a faulty coin mech
you must have at least 3 wires going to the credit board
smythe
Re: COIN MECH HELP
« Reply #12 on: December 04, 2006, 01:10:12 pm »
hi theres 4 going to the cb
2 are black with white bits
one orange with white bits
one green with white/orange bits
think ive blown a fuse while i was checking couple of wires must have touched as the cb dont work also the sound no longer works....
boo hoo
i might just buy a new mech from e-bay there not mega expensive
grantspain
Re: COIN MECH HELP
« Reply #13 on: December 04, 2006, 01:37:27 pm »
if you lost sound and credit board you have blown a fuse on the +12volt line somewhere
smythe
Re: COIN MECH HELP
« Reply #14 on: December 04, 2006, 03:09:18 pm »
yeh ill check the fuses tommorow i think ive got another mech somewhere i had a c220 but cant remember where i put it...
ill try that in morning
any1 any ideas where i could host some picks of the cb?
(free)
cheers to gs for you knowledge up to now
cheers sjj
