Author Topic: vertical games on horizontal screen question  (Read 2241 times)
philby85
  • Last login:August 28, 2008, 08:25:17 pm
« on: November 27, 2006, 08:30:56 pm »
Sorry if this has been asked before or is an easy one. I am running mame32 .99 I have a horizontal 19" lcd in my cab. When I run some vertical games they are aligned in the centre of the screen. Some, for example Galaga run to the left of centre. Is there an option to centre it?
cheers
Philby
philby85
Re: vertical games on horizontal screen question
« Reply #1 on: November 29, 2006, 07:34:45 pm »
Well, finally fixed this one. All are now centered and looking great.
ppilot
  • Last login:January 06, 2020, 01:33:27 pm
« Reply #2 on: November 30, 2006, 01:08:42 pm »
 Sorry, pet peeve of mine.  Please tell HOW you fixed it, and maybe help someone else down the road.
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
« Reply #3 on: November 30, 2006, 04:57:35 pm »
I had faith in you....
philby85
« Reply #4 on: November 30, 2006, 10:21:42 pm »
Aw shucks thanks Loadman!
Well, first off I was using the univert bezel, which worked well but still galaga and others would be off centre. Using mala as a front end as well. even just using mame a few would be off centre. Anyway to cut a long story short, in mala  i turned of the switch resolution check box and all ok. I am not using the univert bezel anymore either.
philby
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #5 on: December 01, 2006, 05:43:08 am »
Yeah switch resolution never sat quite well with me as something that would be good for a cab application...
I may be wrong, but I figure that once you get your resolution and such coordinated and confirmed working on your cab, you wouldn't want to deal with hazards that come with constantly changing resolutions, especially if you're using something like a TV that probably doesn't support many of the games natural resolutions...
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
