Author Topic: FS/FT: PSx hacked controllers w/ adapters & Hackable guns like T2  (Read 1225 times)
taternutz
  • Last login:June 15, 2011, 08:47:22 pm
  • lovin tots since 78
I have a set of steel gunner 2 guns that I was going to use but decided to keep control panel clean
I also have a set of playstation controllers completely hacked apart and soldered. you can see the pics pre-destruction. they also include the adapters for gamecube and xbox as seen the xbox  ends have had usb plugs added
1- had the xbox plugged completely removed
the other I just soldered onto the xbox plug
they have 8 buttons + plus a start and select you can use. I recieved an Ipac to use instead of these
I also have 1 15" crt touchscreen monitor available
no reasonable offer will be turned down.
« Last Edit: November 22, 2006, 12:14:02 pm by taternutz »
taternutz
Re: FS/FT: PSx hacked controllers w/ adapters & Hackable guns like T2
« Reply #1 on: November 23, 2006, 12:58:03 pm »
Is this stuff of any use to anyone. I mean is it usseable in the byoac world??  I am new to this so I just pick stuff up as it comes along.
taternutz
« Reply #2 on: November 28, 2006, 05:51:19 pm »
:BUMP: this is my 1st and only bump to bring back to front page :cheers:
