Author Topic: Anyone know the Capcom Fighter layout inches apart.  (Read 1576 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
« on: November 21, 2006, 11:33:45 am »
Guys any of you know how far apart the 6 buttons are for the capcom layout is?  Is it 1 1/2".  Or bigger.  I think I will be using the 1 1/2" it looks close to how it was on the Street Fighter 2 games, and the Marvel Super Heroes games.
Scumgriever
  • Last login:July 30, 2013, 07:27:31 am
Re: Anyone know the Capcom Fighter layout inches apart.
« Reply #1 on: November 21, 2006, 12:22:04 pm »
Boodroe posted these measurements from his SF2 cabinet in a couple of threads.
http://forum.arcadecontrols.com/index.php?topic=59359.msg585646#msg585646
is one of them.
They have the buttons 1.5" apart.
 EDIT
1 1/2" i mean... I'll never get used to inches.
« Last Edit: November 21, 2006, 12:24:06 pm by Scumgriever »
AlanS17
    • AlanS17
« Reply #2 on: November 21, 2006, 12:23:57 pm »
I was just gonna wing it, but this might come in handy.
2600
« Reply #3 on: November 21, 2006, 01:21:58 pm »
There is a Capcom template from Capcom on the main page under Layout&Design.
DarkBubble
« Reply #4 on: November 21, 2006, 10:39:19 pm »
 EDIT
With all the ten-key I gotta do at work, I've taken to using decimals.  Well, until it gets to things like 7/32"
I need to track down a couple SF cabs and see if I still like the layout or if I wanna try something new.
Crowquill
  • Last login:March 30, 2026, 01:03:12 pm
« Reply #5 on: November 22, 2006, 01:46:22 pm »
One thing I don't think most people realize (or can utilize) about that template is that the PDF still has the capability to be edited by Adobe Illustrator. According to Illustrator, the crosshairs for drilling holes are 1.62" apart horizontally and 1.485" vertically. The joystick hole's center is 4.903" horizontally from the center of the first button. The vertical center falls just below the top set of button holes. It's about 1/8" higher than being actually centered with the buttons.
Obviously, if you're going to use this template for drilling, you'd want to just print it out at 100%. The type is in a different font, but this template is identical to the drilling template printed in my X-Men vs. Street Fighter manual.
I measured a lot of cabinets I found, and tried to find a good compromise between Capcom's layout and the Neo-Geo MVS layout. Attached is my final drilling template. The 7th button, while at an angle, is the same spacing as the six buttons' horizontal spacing (1.62" from the bottom left button). This puts the 7th button pretty close to the joystick, but this placement is very close to the real MVS cabinets.
« Last Edit: November 22, 2006, 02:30:40 pm by Crowquill »
